Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Can someone help me with my standby problem?!
Forum Laptops & Notebooks : General Laptops & Notebooks - Can someone help me with my standby problem?!
Ok I've been searching and searching... but I can't seem to find an answer to my problem. I have a Toshiba A105 and recently it just started acting up. It doesn't go into standby anymore. It doesn't give error messages or anything you click standby.. nothing.. you shut the lid... it turns into a hot plate.
So any help.. at all.. cause this is really irritating.. I depend on standby to go from class to class and what not...
New News... I found I can't hibernate either.. I fiddled with the power settings I put both close the lid and pressing the button on hibernate and nothing. The only thing I can do is hold the power button to fully turn off the laptop. Nothing else works...
Message edited by ApolloX54 on 08-25-2008 at 05:45:09 PM
AMD Athlon x64 X2 5000+ (3.1Ghz)
eVGA 8800GT 512Mb
2Gb G.Skill DDR2800
Sponsored Links
You need to both OS & drivers to do standby/hibernate. OS needs to be set up correctly. i.e. shut lid to stand by. What OS?
For drivers:
http://www.csd.toshiba.com/cgi-bin [...] modSel.jsp
Reply to auscanzukus
I running windows XP MC.. I dunno what happened one moment it's fine the next I shut my lid put it in my bookbag and woke to a very hot bookbag... and that's when I found out it doesn't do standby or hibernate... it doesn't even try... you click the standby button and it just goes one with it's life...
eVGA 8800GT 512Mb
2Gb G.Skill DDR2800
Reply to ApolloX54
I suggest you reinstall any power drivers or anything related with your notebook. If that fails, do a repair on windows.
Check the BIOS to see if there are any awry power settings, too.
Reply to frozenlead
There are 1133 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
