Sort Problem
Last response: in Windows XP
Archived from groups: microsoft.public.windowsxp.general (More info?)
I just went to WinXP and now my sort of files w/n a directory is screwy in
both Windows Explorer and Powerdesk. When I view a file in Detail View and
then click on NAME to sort it, it does not sort like it did in Win98. This
is an example of file name order:
6 byt..
15-1994
721 pv..
1994 ex..
1994.zip. I'm not sure, but it seems like only the files starting with
a numerics are out of sync. Cant find any settings to change anything to do
with sorting.
Frank
More about : sort problem
Disconcerting ain't it! Here's the whys and the way to put it back
The Sort Order for Files and Folders Whose Names Contain Numerals Is
Different in Windows XP Than It Is in Windows 2000
http://support.microsoft.com/default.aspx?scid=kb;en-us;319827
> 6 byt..
> 15-1994
> 721 pv..
> 1994 ex..
> with sorting.
> Frank
Use TweakUI
TweakUI
[+] Explorer
? Use intuitive filename sorting
[[If this is checked the Explorer will sort files so that, for e.g. “File 5”
comes before “File 10” because 5 comes before 10. If this is unchecked then
Explorer will use literal sorting, in which case “File 10” will come before
“File 5” because 1 comes before 5. ]]
Download TweakUI here >>>
Microsoft PowerToys for Windows XP
http://www.microsoft.com/windowsxp/pro/downloads/powert...
Tweak UI
TweakUI.exe
Tweak UI for Windows XP Guide
http://www.winxpsolution.com/Tweakuixppro.aspx
Windows Explorer Incorrectly Sorts Files and Folders with 10 or
More Consecutive Numerals
http://support.microsoft.com/default.aspx?scid=kb;en-us;318872
Hope this helps. Let us know.
Wes
MS-MVP Windows Shell/User
In news:11bjbno3eouk69e@corp.supernews.com,
Frank <fjmet@amisp.net> hunted and pecked:
> and then click on NAME to sort it, it does not sort like it did in Win98.
> This is an example of file name order:
> 6 byt..
> 15-1994
> 721 pv..
> 1994 ex..
> with a numerics are out of sync. Cant find any settings to change
> anything to do with sorting.
> Frank
[Use intuitive filename sorting - when enabled, Explorer will sort files
so that, for example, File 5 comes before File 10. Disabled, Explorer
will use literal sorting, in which case File 10 will come before File 5,
because 1 comes before 5 (literal sorting used to be Windows default
behaviour before Windows XP)].
Download and install -TweakUI 2.10 [If you have the old TweakUI
installed, you must uninstall it before installing the new one]
http://tinyurl.com/h8zs
regards,
ssg MS-MVP
> 6 byt..
> 15-1994
> 721 pv..
> 1994 ex..
> with sorting.
> Frank
Related ressources
I already have Tweakui 2.10.0.0. Where is this setting???
Frank
"S.Sengupta" <ssengupta_@msn.com> wrote in message
news:eGcEhO6dFHA.2520@TK2MSFTNGP09.phx.gbl...
> so that, for example, File 5 comes before File 10. Disabled, Explorer will
> Download and install -TweakUI 2.10 [If you have the old TweakUI installed,
> regards,
> ssg MS-MVP
>> in both Windows Explorer and Powerdesk. When I view a file in Detail
>> View and then click on NAME to sort it, it does not sort like it did in
>> Win98. This is an example of file name order:
>> 6 byt..
>> 15-1994
>> 721 pv..
>> 1994 ex..
>> Frank
TweakUI
[+] Explorer
Wes
In news:11blr8f5hfptk0b@corp.supernews.com,
> Frank
>> regards,
>> ssg MS-MVP
>>> 6 byt..
>>> 15-1994
>>> 721 pv..
>>> 1994 ex..
>>> Frank
Thanks, that worked great.
Frank
"Wesley Vogel" <123WVogel955@comcast.net> wrote in message
news:o 2u156OeFHA.1040@TK2MSFTNGP10.phx.gbl...
> TweakUI
> [+] Explorer
> Wes
>> Frank
>>> regards,
>>> ssg MS-MVP
>>>> 6 byt..
>>>> 15-1994
>>>> 721 pv..
>>>> 1994 ex..
>>>> Frank
Keep having fun, Frank. :-)
Wes
In news:11brl0iepqpaibb@corp.supernews.com,
> Frank
>> TweakUI
>> [+] Explorer
>> Wes
>>> Frank
>>>> files so that, for example, File 5 comes before File 10. Disabled,
>>>> Explorer will use literal sorting, in which case File 10 will come
>>>> before File 5, because 1 comes before 5 (literal sorting used to be
>>>> Windows default behaviour before Windows XP)].
>>>> regards,
>>>> ssg MS-MVP
>>>>> screwy in both Windows Explorer and Powerdesk. When I view a file in
>>>>> Detail View and then click on NAME to sort it, it does not sort like
>>>>> it did in Win98. This is an example of file name order:
>>>>> 6 byt..
>>>>> 15-1994
>>>>> 721 pv..
>>>>> 1994 ex..
>>>>> starting with a numerics are out of sync. Cant find any settings to
>>>>> change anything to do with sorting.
>>>>> Frank
Ask the community
