GREAT!
After some problems with my 9600 pro aka 9600 series,
now i seem to have some preoblems with my hard drive.
I have a 120 gb 7200 rpm seagate baracuda (which shows up as
111.79 gb in xp's disk management)
A friend had come to my place to set the system up (.hacker.)
he formatted only 20 gigs just to get started and installed xp
From xp's disk manager i saw that the free space which showed up
was 95.25 gigs , so i created a logical drive from there [using the wizard]
and formatted it . The drive was 19.5 gigs [ NTFS ] , when i checked the
properties of this drive , the used space showed upto be 65 mb,
even when the drive had no files on it.Does this space account for some
system files ? or is something wrong with the drive
any way i deleted the drive.
heres the break up of the Current drives
C: [primary] [FAT 32 file system] 9.75 gb which shows up well
D: [ ntfs File system] 9.76 gb out of which , i have used up 6.75 gb and
in explorer used space shows up as 6.81 gb ie a 90 mb difference.
Another odd thing is that when i add up 9.75 + 9.76 + 95.25 , i get 114.76 ,
which exceeds the capacity mentioned []
As of now no motherboard/cd-rom/sound card problems .....yet,
[Floppy drive problem was solved [] ]
