Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Intermittent problem connecting with Remote Desktop
Forum Windows XP : Windows XP General Discussion - Intermittent problem connecting with Remote Desktop
Archived from groups: microsoft.public.windowsxp.work_remotely,microsoft.public.windowsxp.general (More info?)
I wish to work from home sometimes. So, I leave my work PC on when I
leave at night. My work PC is XP Pro SP2, my home PC is W2k.
This morning I tried to connect using Remote Desktop. I could see my
work desktop login for a second or two, then it would just bomb out. I
tried again and again. Sometimes I would get a "Network error"
message.
So, I came in to work. My PC is locked, as I'd expect (it is also set
to go into standby mode after 15 minutes). I unlocked it and began
working. When my wife called from home, I asked her to try to connect,
and she was able to connect with no problems.
So, it appears that if my work PC is active and unlocked, I can connect
from home. If it is on standby (and/or locked), I cannot. Does this
sound right?
TIA
Edward
Sponsored Links
If its in standby you need to look at using Wake-On-LAN to wake it up...
http://www.michna.com/kb/WxWOL.htm
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual
benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no
rights...
<teddysnips@hotmail.com> wrote in message
news:1119519696.464277.302860@o13g2000cwo.googlegroups.com...
> message.
> sound right?
> TIA
> Edward
Reply to Anonymous
Hi,
I've run into some issues with this. It commonly occurs if the use fully
logs out, the RD access is denied. If left logged in, even if the station is
locked, the RD access works ok. Haven't been able to bug it out yet, so as a
workaround I leave the target account logged on, but with the station
locked.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Associate Expert - WindowsXP Expert Zone
www.microsoft.com/windowsxp/expertzone
Windows help - www.rickrogers.org
> message.
> sound right?
> TIA
> Edward
Reply to Anonymous
> connect from home. If it is on standby (and/or locked), I cannot.
If either your processor ("system" ) or your NIC has gone into standby, then
you cannot make incoming connections.
It does not matter whether or not your monitor has gone into standby.
Check your control panel Power Options. Set "System standby" and "System
hibernates" to "Never".
Robin Walker [MVP Networking]
rdhw@cam.ac.uk
Reply to Anonymous
> fully logs out, the RD access is denied. If left logged in, even if
> the station is locked, the RD access works ok.
This is usually a video driver problem on the RDC server. Update your video
drivers with the latest version from the website of the manufacturer.
rdhw@cam.ac.uk
Reply to Anonymous
Thanks for all your suggestions. WakeOnLan worked a treat.
Edward
Reply to Anonymous
There are 1090 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
