Archived from groups: microsoft.public.windowsxp.general (
More info?)
Thanks for that I followed yourexcellent instructions but cannot get a high
resolution for monitor when I try to change from 640 x 480 to anything
higher it goes into stanby mode again
Thanks Andrewllan
"Malke" wrote:
> Andrewllan wrote:
> > AT 4 I installed card and booted machine
> > The CRT went straight into stanby mode.
> > I then switched off unistalled card and rebooted.
> > I then went to web site updated drivers for motherboard
> > as it said in instructions
> > I then when to device manger and disabled display adapters
> > I then switched off and rebooted
> > It reconised the card but when the screen went blank after Windows
> > logo it went back to stand by mode!
> > "Andrewllan" wrote:
> >> The graphics are integrated and I am not aware of anything in add or
> >> remove to delete
> >> "Malke" wrote:
> >> > Andrewllan wrote:
> >> > > I have an AMD Athlon 1800 the mother board chip set is VIA
> >> > > KT133/A I have tried to install new graphics card INN GEforce
> >> > > 64mb. Have d/l upto date motherboard drivers and have disabled
> >> > > display adapters. When I boot up I get to the Window XP logo
> >> > > screen it blanks and then the CRT goes to standby mode are their
> >> > > any other bits I need to disable Thanks Andrew
> It sounds like the drivers are calling a resolution that your monitor
> can't handle, such as 1280 x 1024 when your monitor may only be able to
> handle 1024 x 768. Go into Safe Mode* and once there, do:
> Start>Run msconfig [enter]
> Now go to the BOOT.INI tab and put a check in the box next
> to /BASEVIDEO. Apply and OK out and when you get the prompt to restart,
> do so. Allow the computer to boot into regular mode. The graphics will
> be ugly. Go to the Display applet in Control Panel and from the
> Settings tab set the resolution to something you know your monitor will
> handle. Unless you've got an ancient 15" monitor, 1024 x 768 should be
> OK. Don't forget to go back to msconfig and uncheck /BASEVIDEO.
> *In case you don't know (I'm not saying this to offend you), to get into
> Safe Mode repeatedly tap the F8 key as the computer is starting up.
> This will get you to the menu where you can choose Safe Mode.
> Malke
> Elephant Boy Computers
> www.elephantboycomputers.com
> "Don't Panic!"
> MS-MVP Windows - Shell/User
