Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I have an MN-700 router. I need to either vnc or do a
remote desktop connection from work to home. I know my
cable isp blocks all common ports. I also set up port
forwarding on my router for those common ports and also
other ports. Is there any way that i can set either of
those up without using common ports. I have it working
within my network. If i put my router given ip address in
it will work. If i give the ip given by my isp it will
not. Someone please help.
Have you tried testing it from outside your network? AFAIK the MN-700 does
not support "loopback" - in other words, referring to your external IP from
inside your network will not work (apparently MS is working on supporting
this feature sometime in the future) It may be that the port forwarding
would work fine if you are coming from the outside (a friend's house?)
HTH
"Jano" <anonymous@discussions.microsoft.com> wrote in message
news:231c501c45ea2$746fe6a0$a601280a@phx.gbl...
No i havent tried that...i thought that router supported
loopback..do you think if it was working for me internally
with the ports i specified it would work outside of my
network??
>-----Original Message-----
port forwarding
friend's house?)
>HTH
message
in
I believe that it likely would work. Best to try it however from work or a
friend's house etc.
There are rumours in this ng that MS will be releasing a firmware upgrade
for the MN-700 (perhaps others) and some have speculated that this would
have to coincide with the release of XP-SP2 since some other items have to
be taken care of in the wireless product line for compatibility with SP2...
I am just a user of MS wireless products and a lurker here so I have no
specific knowledge of anything MS might or might not be doing.
HTH
news:23b4701c45ead$d78901d0$a501280a@phx.gbl...
> network??
> port forwarding
> friend's house?)
> >HTH
> message
> in
Well thanx for everything. I am going to try this when i
get home tonite. I will let you know tomorrow.
>friend's house etc.
firmware upgrade
that this would
other items have to
here so I have no
doing.
>HTH
message
internally
>> network??
the
>> port forwarding
>> friend's house?)
>> >HTH
>> message
a
my
port
also
of
working
address
>> in
will
I have this working on my network without a problem. If
you can't get it working, email me and we can compare
settings.
Keep in mind that I very rarely check this board, and I'm
only in email once in a while, so my response may not be
immediate.
FWIW, I agree with Rich and Kerry.
This is probably already working. I doubt that your ISP blocks these ports.
I'd stick with Remote Desktop, unless you've downloaded and are using the
encryption piece for use with some newer VNC variants--UltraVnc, for
example.
Good help may be found in newsgroup:
microsoft.public.windowsxp.work_remotely
news:239a801c45ec1$e4870710$a301280a@phx.gbl...
>>friend's house etc.
> firmware upgrade
> that this would
> other items have to
> here so I have no
> doing.
>>HTH
> message
> internally
>>> network??
> the
>>> port forwarding
>>> friend's house?)
>>> >HTH
>>> message
> a
> my
> port
> also
> of
> working
> address
>>> in
> will
Thank you all for your help. My remote desktop connection
is now running great. Another question though. Do any of
you run an ftp server? If so what program do you use. I
was using Serv-U and i was able to log in just fine but i
can not get it to list the directory and then it drops the
ftp connection?
>>friend's house etc.
>firmware upgrade
>that this would
>other items have to
>here so I have no
>doing.
>>HTH
>message
supported
>internally
>>> network??
>the
>>> port forwarding
>>> friend's house?)
>>> >HTH
>>> message
do
>a
know
>my
>port
>also
either
>of
>working
>address
>>> in
>will
ftp connection?
>>friend's house etc.
>firmware upgrade
>that this would
>other items have to
>here so I have no
>doing.
>>HTH
>message
supported
>internally
>>> network??
>the
>>> port forwarding
>>> friend's house?)
>>> >HTH
>>> message
do
>a
know
>my
>port
>also
either
>of
>working
>address
>>> in
>will
I would look at Filezilla - a great freeware FTP client AND server:
http://filezilla.sourceforge.net/
The problem you are currently experiencing is likely due to your server not
configured to handle passive FTP - you may want to read up on that issue
too.
HTH
news:23efe01c45f70$28fb9a10$a601280a@phx.gbl...
> ftp connection?
> >>friend's house etc.
> >firmware upgrade
> >that this would
> >other items have to
> >here so I have no
> >doing.
> >>HTH
> >message
> supported
> >internally
> >>> network??
> >the
> >>> port forwarding
> >>> friend's house?)
> >>> >HTH
> >>> message
> do
> >a
> know
> >my
> >port
> >also
> either
> >of
> >working
> >address
> >>> in
> >will
Sounds like you need to setup passive mode.
Forward a bunch of ports (30000-30009) to the computer running Serv-U
Then tell Serv-U to use those ports (30000-30009) for passive mode and tell
Serv-U to use your WAN IP as the passive mode ip.
That should take care of that.
Active mode issues are always due to the person connecting to the FTP.
Without an ALG, active mode is very difficult to get working through
firewalls and/or shared connections due to the way it expects to see
listening ports (your firewall/router/whatever won't know to open those
ports and direct them to the requesting computer)... hence the need for
passive mode FTP
Jason Tsang - Microsoft MVP
Find out about the MS MVP Program -
http://mvp.support.microsoft.com/default.aspx
news:2407e01c45f7e$3d349230$a601280a@phx.gbl...
> ftp connection?
> >>friend's house etc.
> >firmware upgrade
> >that this would
> >other items have to
> >here so I have no
> >doing.
> >>HTH
> >message
> supported
> >internally
> >>> network??
> >the
> >>> port forwarding
> >>> friend's house?)
> >>> >HTH
> >>> message
> do
> >a
> know
> >my
> >port
> >also
> either
> >of
> >working
> >address
> >>> in
> >will
I tried that. When i was using my ip in there. It wasnt
even connecting. I setup passive mode though but it is
still not bringing in the directory listing. Anymore
ideas?
connection
of
the
>ftp connection?
i
>>>friend's house etc.
a
>>firmware upgrade
speculated
>>that this would
>>other items have to
>>here so I have no
>>doing.
>>>HTH
>>message
>supported
>>internally
>>>> network??
that
>>the
>>>> port forwarding
>>>> friend's house?)
>>>> >HTH
>>>> message
>do
>>a
>know
>>my
>>port
and
>>also
>either
>>of
>>working
>>address
>>>> in
>>will
There is no loopback support in the MN700 (yet)
so if you are trying to use passive mode from within your own LAN, it won't
work.
news:2439301c45f9f$654b02b0$a601280a@phx.gbl...
> ideas?
> connection
> of
> the
> >ftp connection?
> i
> >>>friend's house etc.
> a
> >>firmware upgrade
> speculated
> >>that this would
> >>other items have to
> >>here so I have no
> >>doing.
> >>>HTH
> >>message
> >supported
> >>internally
> >>>> network??
> that
> >>the
> >>>> port forwarding
> >>>> friend's house?)
> >>>> >HTH
> >>>> message
> >do
> >>a
> >know
> >>my
> >>port
> and
> >>also
> >either
> >>of
> >>working
> >>address
> >>>> in
> >>will
No, i was trying it from another network. It still would
not let me in.
own LAN, it won't
>work.
message
wasnt
>> ideas?
>> connection
>> of
use. I
but i
>> the
>> >ftp connection?
when
>> i
>> >>>friend's house etc.
releasing
>> a
>> >>firmware upgrade
>> speculated
>> >>that this would
some
>> >>other items have to
>> >>here so I have no
be
>> >>doing.
>> >>>HTH
>> >>message
>> >supported
>> >>internally
of my
>> >>>> network??
network?
referring to
is
>> that
>> >>the
>> >>>> port forwarding
outside (a
>> >>>> friend's house?)
>> >>>> >HTH
wrote in
>> >>>> message
or
>> >do
>> >>a
>> >know
>> >>my
up
>> >>port
>> and
>> >>also
>> >either
>> >>of
>> >>working
>> >>address
>> >>>> in
it
>> >>will
There are 758 identified and unidentified users. To see the list of identified users, Click here.
