Closed Solved
!HELP! I have an issue with multipul Taskeng.exe running
Sorry if this is in the wrong place. Anyways my problem is that I have numerous taskeng.exe running on my pc. I don't believe I have a virus, I have scanned malwarebytes and avast anti virus and nothing has come up. I've checked the file location and all seems normal. I have using Windows 7 Ultimate Edition 64 bit running, 4GB of DDR2 RAM, Intel Core 2 Quad Q6800 Defualt Clock. Anyways thanks!
12 answers Last reply Best Answer
More about help issue multipul taskeng running
  1. Could someone please help?
  2. Do you use IE7 ?
  3. "This is the task scheduler service under Windows Vista and Windows 7. It is responsible for keeping track of tasks set to run at a time predetermined by the user, and to invoke them when necessary. http://www.neuber.com/taskmanager/process/taskeng.exe.html
    Note: The taskeng.exe file is located in the folder C:\Windows\System32. In other cases, taskeng.exe is a virus, spyware, trojan or worm!"
    Right from the web
  4. correon said:
    Do you use IE7 ?
    No I do not. I use Google Chrome only.
    Right from the web
    It's the fact that their is 10 of taskeng.exe running, I know what it does but I only require one to run which why I am at a loss.
  6. You can go into the task scheduler and see what has been setup. I would say it could be a virus if you have that many running.
  7. Best answer
    Hi :)
    Is it a LEGAL Ultimate ? as a LOT of the illegal downloaded ones come with a rather nasty set of viruses and trojans... ?
    All the best Brett :)
  8. Brett928S2 said:
    Hi :)
    Doesn't have to be ;) But you could say it is. Yes I do torrent quite a fair bit but it isn't exactly illegal where I live due to our mighty fine copyright laws. As long as you do not sell or share you are fine. Also I ended some Old task and odd tasks within the scheduler and I went throught EVERYTHING so I believe it could of been a old error or possibly somethings worse. Anyways everyone I do not believe I have solved it as I just did this 5 mins ago. Also if I did have a virus of some form usually files would go missing, accounts would be hacked or solved, also larges sums of money would have disappeared from my bank account which has not happened, so which leads me to believe it is a bug of some form.
  9. Well I won't help with software not legally purchased.
  10. Hi :)
    We are NOT allowed to help with ILLEGAL OPERATING sytems or any other illegal software here at Toms...
  11. This topic has been closed by Proximon
  12. Best answer selected by Proximon.
Windows 7
