Hiiiiiiii friends Yesterday i download autocad 2012 Named {Autodesk autocad 2012}
First i got some problem on installing it but i manage it by some ways Now i have install it But I can't Run it .It shows an error message:-
As;-
C:\Program files\Autodesk\autocad 2012-english\acad.exe
The application has failed to start because its side- by-side configuration is incorrect .Please see the application event log or use the command line sxstrace.exe tool for more detail.
Here is the setup log file
2012/8/22:19:35:06 PuniA SANDEEP === Setup started on SANDEEP by PuniA ===
2012/8/22:19:35:06 PuniA SANDEEP Launch
2012/8/22:19:36:18 PuniA SANDEEP === Setup ended ===
2012/8/22:19:35:10 PuniA SANDEEP === Setup started on SANDEEP by PuniA ===
2012/8/22:19:35:10 PuniA SANDEEP Launch
2012/8/22:19:35:10 PuniA SANDEEP [Error: 1052] The requested control is not valid for this service.
2012/8/22:19:36:20 PuniA SANDEEP PageOpen LaunchDialog
2012/8/22:19:36:38 PuniA SANDEEP PageOpen LicenseDialog
2012/8/22:19:36:42 PuniA SANDEEP PageOpen ProductInfoDialog
2012/8/22:19:38:37 PuniA SANDEEP PageOpen ProductSelectionDialog2
2012/8/22:19:39:20 PuniA SANDEEP PageOpen FullProgressDialog
2012/8/22:19:39:20 PuniA SANDEEP Installing Microsoft Visual C++ 2005 Redistributable (x86): I:\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\PuniA\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/8/22:19:39:51 PuniA SANDEEP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
2012/8/22:19:39:51 PuniA SANDEEP Installing Microsoft Visual C++ 2008 SP1 Redistributable (x86): I:\3rdParty\x86\VCRedist\2008SP1\vcredist_x86.exe /q
2012/8/22:19:40:16 PuniA SANDEEP Install Microsoft Visual C++ 2008 SP1 Redistributable (x86) Succeeded
2012/8/22:19:40:16 PuniA SANDEEP Installing Microsoft Visual C++ 2010 Redistributable (x86): I:\3rdParty\x86\VCRedist\2010\vcredist_x86.exe /q /l C:\Users\PuniA\AppData\Local\Temp\vcredist_x86_2010.log
2012/8/22:19:40:20 PuniA SANDEEP Install Microsoft Visual C++ 2010 Redistributable (x86) Failed Installation aborted, Result=1603
2012/8/22:19:40:21 PuniA SANDEEP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
2012/8/22:19:40:22 PuniA SANDEEP PageOpen InstallCompleteDialog
2012/8/22:19:40:56 PuniA SANDEEP === Setup ended ===
2012/8/22:19:42:27 PuniA SANDEEP === Setup started on SANDEEP by PuniA ===
2012/8/22:19:42:27 PuniA SANDEEP Launch
2012/8/22:19:42:38 PuniA SANDEEP === Setup ended ===
2012/8/22:19:42:28 PuniA SANDEEP === Setup started on SANDEEP by PuniA ===
2012/8/22:19:42:28 PuniA SANDEEP Launch
2012/8/22:19:42:38 PuniA SANDEEP PageOpen LaunchDialog
2012/8/22:19:43:12 PuniA SANDEEP PageOpen LicenseDialog
2012/8/22:19:43:17 PuniA SANDEEP PageOpen ProductInfoDialog
2012/8/22:19:43:47 PuniA SANDEEP PageOpen ProductSelectionDialog2
2012/8/22:19:44:08 PuniA SANDEEP PageOpen FullProgressDialog
2012/8/22:19:44:09 PuniA SANDEEP Installing .NET Framework Runtime 4.0: I:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/8/22:19:44:42 PuniA SANDEEP Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
2012/8/22:19:44:43 PuniA SANDEEP PageOpen InstallCompleteDialog
2012/8/22:19:45:15 PuniA SANDEEP === Setup ended ===
2012/8/22:19:45:22 PuniA SANDEEP === Setup started on SANDEEP by PuniA ===
2012/8/22:19:45:22 PuniA SANDEEP Launch
2012/8/22:19:45:32 PuniA SANDEEP === Setup ended ===
2012/8/22:19:45:23 PuniA SANDEEP === Setup started on SANDEEP by PuniA ===
2012/8/22:19:45:23 PuniA SANDEEP Launch
2012/8/22:19:45:32 PuniA SANDEEP PageOpen LaunchDialog
2012/8/22:19:45:51 PuniA SANDEEP PageOpen LicenseDialog
2012/8/22:19:45:55 PuniA SANDEEP PageOpen ProductInfoDialog
2012/8/22:19:46:01 PuniA SANDEEP PageOpen ProductSelectionDialog2
2012/8/22:19:47:09 PuniA SANDEEP PageOpen FullProgressDialog
2012/8/22:19:47:09 PuniA SANDEEP Installing .NET Framework Runtime 4.0: I:\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2012/8/22:19:47:35 PuniA SANDEEP Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
As;-
