Shut down Problem
Forum Windows 95/98/ME : Windows 95/98/Me General Discussion - Shut down Problem
When I shutdown windows 98, my computer pauses at "Please Wait..." screen. Yet there is no improper shutdown error message when I again start the windows.
Any suggestions...!
Sponsored Links
Are you saying it freezes at the "please wait" message and you have to press reset?
If so the shutdown process sends a signal to tell the system that shutdown type X occured. If you usually press reset, shutdown X did not occur, so run scandisk. The message is probably after the sent signal, so the system thinks all is cool.
If you want a further explaination, check out memory address registers in a search engine.
<b><font color=blue>~ What do you mean "It isn't working!"...Now where's my sonic screwdriver? ~ </font color=blue></b>
Reply to camieabz
have u changed ur logos.sys and logow.sys files? maybe u replaced the logos.sys file with the logow.sys file. go into paint and load them up and check. other than that i wouldnt worry too much if u dont have to run scandisk at restart.
Reply to sturm
<A HREF="http://www.windows-help.net/windows98/troub-51.shtml" target="_new">Windows 98 Second Edition Shutdown Problems</A>
<A HREF="http://support.promise.com/techsupport/Notes/dealing_with_shutdown_issues_in_.htm" target="_new">Dealing with Shutdown Issues in Windows 98/98SE</A>
<A HREF="http://www.computerhope.com/issues/ch000285.htm" target="_new">Microsoft Windows does not Shut Down</A>
Toejam31
<font color=red>First Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=17935" target="_new"><font color=green>Toejam31's Devastating Dalek Destroyer</font color=green></A>
<font color=red>Second Rig:</font color=red> <A HREF="http://www.anandtech.com/mysystemrig.html?rigid=15942" target="_new"><font color=green>Toey's Dynamite DDR Duron</font color=green></A>
__________________________________________________________
<font color=purple>"Some push the envelope. Some just lick it. And some can't find the flap."</font color=purple>
Reply to Toejam31
<A HREF="http://www.annoyances.org/exec/show/article07-015" target="_new">http://www.annoyances.org/exec/show/article07-015</A>
If this is due to some driver that is not unloading, can you find which driver is the culprit?
Reply to xyz
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > Shut down Problem
There are 604 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
