Tom's Hardware > Forum > Old Man/Woman's Club > Other > Electricity, UPS and PC power issue
Forum Old Man/Woman's Club : Other - Electricity, UPS and PC power issue
Yesterday morning, I was smelling that nice smell you get when you first buy a new PC, ya know, the fresh wire smell. Ironically this is the same smell when you have BURNT wire.
Well, it sounded innocent at first, but after an hour or so, it started smelling more, which indicate it wasn't normal. Finally, a few minutes after, the PC turns off on its own. I knew it wasn't normal at all because the UPS would've kicked in as it always has.
I look behind, and could smell some burnt electronics from the PSU. At this point I am getting quite nervous, hoping it didn't fry anything else like the HDD, because I had my family project prepared for today. So I call my uncle, and he tells me to unplug the PC power cord from the UPS and put it in the power bar instead. I turn it on, it all works, and has been since yesterday.
So now I am wondering, just what happened? My UPS has been here for two years now, and has always kicked in right when it was needed. It is an APC Back-UPS 650VA, rated 400W. My system's a measily AthlonXP 1.4GHZ with a Ti200 64MB video card, one 80GB HDD, 16*10*40 CD-RW, 512MB DDR, and an 300W Antec PSU. Those are about all I can tell that are the most power drawing components from the computer. I also have the 17" CRT monitor and sound system also plugged in the UPS.
Anyone know what happened? Like I said, the system is far from being too much on the UPS, it has always worked when needed, for many minutes too. It usually can last 10 minutes actually. So I don't think it's a power load issue more than some other electrical one.
<font color=blue>Ede</font color=blue>
Sponsored Links
first CALL UR UNCLE? WHAT ABOUT THE REST OF US! I feel left out :(
second, its is just god's way of telling you "time to have a major upgrade :D"
RIP Block Heater....HELLO P4~~~~~
120% nVidia Fanboy+119% Money Fanboy
GeForce 6800 Ultra--> The Way we thought FX 5800Ultra is meant to be played
THGC's resident Asian and nVboy :D
Reply to coolsquirtle
- 0 +
That's pretty weird. I would have expected the UPS to start stinking if it was the problem. Try putting something else on the UPS to see if it works ok. Try plugging the system back into the UPS and power it up. The only time I've seen issues with UPS's is when the battery needs replacing, which means the PC loses power when the mains fail. Since the odor came from the PSU, I would check there. Also, sniff around inside the case just to be sure. But my gut feeling is a PSU on the way out.
Jarrett
Reply to jheine
- 0 +
Did you find out which part was burning? Was it the power supply in your computer or was it the battery charger, surge suppressor in your UPS?
At work we have hundreds of UPS backup units. It's not uncommon for them to fail. When they fail its usually because a plate in the battery shorts and the charging circuit overloads and burns up.
<font color=red><i>Doctor Hooter</i></font color=red> <A HREF="http://www.page3.com/" target="_new"><b>(·Y·)</b></A>
Reply to zpyrd
- 0 +
Definitely the PSU has the smell. Like I said, when I smell from the back of the case, the fan exhaust of the PSU, the odor can be caught.
If it were the UPS, it'd come from there.
Crap, now I am starting to smell it again though. :eek:
Will see what happens tommorow. I'm planning a major upgrade this winter, so I guess I might as well just go buy the PSU already. Was thinking of either the NeoPower 480W or the Enermax Dual Fan 550W. Both similarly priced.
What do you think I can do to the UPS though? Like, if it really were the issue, what can I do now? I really have no clue if APC will replace it or do something about it. I don't either know how long the warranty lasts. But the thing is, it prolly IS the PSU, just that I don't know why it now began to create problems.
Reply to eden
- 0 +
Quote :
I could try the slot where it happened. Since the other components are still plugged in and work fine.
Quote :
Yeah, smelling the inside doesn't seem to give many hints. Very likely the PSU, since the exhaust fan is getting that odor out.
Reply to eden
major upgrade is not coming fast enough :P
- 0 +
If the smell is from the PSU then the PSU is probably malfunctioning.
Use a voltmeter to check your input and output voltages on the UPS. They should be the same.
The UPS has the PowerChute software that will tell you if something is wrong.
Do you regularly clean the dust from your computer? PSU's seem to collect the most dust.
Reply to zpyrd
- 0 +
I clean it about every 3 months. It hasn't been a month I believe since I cleaned it.
I don't have PowerChute installed anymore, since I use the Windows XP UPS service instead. I dunno how useful will the PowerChute be, since the UPS is the kind that communicates to inform it's on battery power, but does not give you any extra info like voltages, or even battery charge.
Reply to eden
- 0 +
I couldn't use WinXP to monitor my APC UPS. I don't know why it will not work.
I use the PowerChute software and it gives voltage, battery status, how long the battery has been in use, how many times it has switched to battery power, etc.
Anyway it sounds like you psu is degrading rapidly. Time to replace it. Are you sure its not a motherboard component or a drive that's going bad? Sometimes the smell gets pulled through the psu exhaust fan.
I have had that happen before. I have seen the controller on a hard drive fry but had no idea what component had actually failed until I did a close inspection of every piece of hardware.
Reply to zpyrd
- 0 +
But then why would the PSU itself go down, if something like the HDD had an issue? I mean, the HDD isn't the one that could turn off a PC, right?
Technically it could fry and the PC would continue running, just no drive detected, at least that's what I'm assuming.
Yeah my UPS is the Back-UPS one, as I said, so it won't read much data in the end. Maybe the software detects a history of usage, but certainly not anything about the actual charge in there, or best yet, the load.
Reply to eden
- 0 +
Its probably the PSU. I forgot that you said the computer shut off by itself.
Reply to zpyrd
- 0 +
On a possibly related issue, the PC has been, since the beginning of the year (and at some extended periods during the year not had the issue) had an odd fan noise. At first it was more rrrrrrrr that was loud, that happened during operation, and would just whine at times from low to high in noise. Later on, a new sound popped that seemed to replace that one, but now it's a higher pitched whining than roaring of a fan. I still can't pinpoint where it comes from!
I had a hunch it was the video card fan, since holding a pen thru it had such noise come out, but I could be wrong. It could also be the northbrige fan. Certainly not the CPU one though, because it continues the same sound during those odd fan noises. Thankfully it's the one component that so far has been working right. Considering it's running often at max speed and has had its share of dust, I'm amazed at the Volcano 7's durability.
My uncle suggested today the HDD too BTW, but I do think it is safe to discard it from the probable causes. It wouldn't be functioning as properly as now if it had issues, and most certainly some other noise from an HDD, like clanking would be heard, no?
I currently have the case opened, the side is close to it, but not put in place. So a little bit of air can enter easily.
I just haven't yet changed a PSU or installed one ever, in fact 3 years ago the PC was built by technicians. Now I'm getting ready to build my own this winter. So I am really hoping I won't change this PSU before New Year, so I won't have to buy a new PSU, the one I will get, and start using it in such a system.
On one hand though, you guys could be right, dust might be the culprit. It could be doing some serious devastation inside the PSU. Is that possible for it to create enough damage for such an odor to come up?
Reply to eden
- 0 +
Sure could. Put a pyle of dust on a hot stove and it'll start stinking. It'll probably catch fire too.
I wouldn't figure the HDD, just because it's not getting noisy and it still works. It also wouldn't cause the system to turn off. If the HDD went belly-up, your system would freeze, maybe even blue screen and reboot, but it wouldn't shut down.
Hopefully, the problem is the PSU, as the next item down the chain would be the Motherboard, and I know you don't want to think about that. I don't even want to think about it.
Oh, and if you decide to replace the UPS, not that you need to, but I've found PowerWare to be pretty good, and costs less than APC. Management software is good too, and depending on the model, you can split the outlets into two zones. I started using them at work over a year ago, and have no complaints at all.
Jarrett
Reply to jheine
- 0 +
Well, one thing I will definitely do above all, especially after even the technician at work told me the same thing too (better do somethin' or the PSU might fry and take away other components with it too!), is backup. Started archiving all data important into one folder. Damn, I'll need about 6 CDs at least. (crazy)
I need a DVD burner.
Now I do wonder how reliable are DVDs for backups? CDs seem to actually be losing their readability lately, and I wonder if DVDs are more resistant and durable. It'd rock to need one DVD only to burn backups, but I am worried about long-term use of the media, as I have no clue on researches on their durability. I know CD-Rs can even lose quality within a year sometimes. The estimated 100 years of information preservation of a CD turned out to be a fake and rather the average was 3 years.
And finally, I know that I didn't still pinpoint the actual fan or component that has the odor. But I'll drop by this saturday and see a technician friend, since the last thing I'd risk is opening the PSU itself. If it's a new on needed, well, pop in another cheap one for now... :eek: No sense in buying a brand new one for the next system and start using it on this one.
At least it's easier now to pinpoint the fan noise at startup, since it's now very frequent and can happen anytime if you close the comp for an hour or so, so I can use it before going to see the technician and it'd prolly have been shut off long enough for the sound to pop up again.
Reply to eden
- 0 +
I would imagine that DVDs are somewhat similar to CDs in durability and reliability. It's really hard to say how long things will really last unless you try it yourself. I've never had an issue with CDs. I've been avoiding DVD's because of the format war, which is mute now that most manufacturers support both formats. As long as you take care of the backup, it should last for as long as you need it.
It's really not worth the trouble popping the PSU open when you can get a cheap one for $20-30. Plus, you have to watch those capacitors, as they'll hold enough juice to send you across the room.
Jarrett
Reply to jheine
- 0 +
Yeah, I'll either ask a friend who's had experience with opening PSUs (it could really just be dust burning) or just get a new one.
Reply to eden
- 0 +
You are worrying way too much about this problem.
Your 99% sure the psu is causing the problem.
You don't want to buy a high end psu because you're going to build a new computer in a few months.
Go to your local computer store and get a generic $40 psu and put it in your old computer.
Get a Sparkle psu. They're made by Fortron Source.
Reply to zpyrd
- 0 +
Quote :
Zyp, that's what I was hinting at with my last post. Some cheap priced 300W one will take care of the PC for the next two months.
I WOULD say it's likely the PSU too, because it turned everything off. I WILL however have the system checked by a technician friend, he's always helped us out anyways. No sense in personally risking opening the PSU.
Reply to eden
- 0 +
fuses inside of psu's go all the time, you dont need to be an expert to change a fuse :tongue: .
"Never underestimate the predictability of Stupidity."
<A HREF="http://www.cameronwilliamson.com" target="_new">-={Neurotic Narcissist.}=-</A>
<font color=green>{FLM}</font color=green>
Reply to mrface
- 0 +
Hmmm ok [innocent]I'll try that today! This is gonna be interesting, if you say so![/innocent]
:tongue:
Reply to eden
- 0 +
remember to stick your tongue to the fuse while you plug it in. :tongue:
Reply to mrface
- 0 +
That's what I had recommended to Phial. What a sweetheart, he follows everything I tell him to do.
Though he had trouble speaking the next day. I wonder why.
Reply to eden
- 0 +
wasnt it willamette who said he sttuck his tongue against the monitor cable to see if any voltage came out of it?
do you remeber that?
Reply to mrface
- 0 +
Him or Flammy one!!! :lol:
<==== Should be (Forum <font color=red>Coors </font color=red> Master) [/shrug]
Dazzle them with Brilliance, or Baffle them with BS! :wink:
<font color=red>{FMCD}</font color=red>
Reply to RCPilot
- 0 +
so when are you gonna change your title to <font color=red>{FCM}</font color=red>???
Reply to mrface
- 0 +
I think I remember someone did. But uh...dunno how they survived, lmao.
Heck, using a tongue to detect voltage is pretty damn ridiculous as it is.
Reply to eden
- 0 +
I can't get it done, I guess...
Reply to RCPilot
- 0 +
it was only like 5v that comes out but still its the idea, lol.
Reply to mrface
- 0 +
Flamey for sure. After all, he ate cookies found behind his computer or monitor.
Reply to eden
- 0 +
That's not the least of what he's eaten!!! :eek:
Reply to RCPilot
- 0 +
he had a cheese block the size of a car battery, it weighed 300 lbs. he would lift weights with it and then eat the whole block.
Reply to mrface
- 0 +
I was think of the cheese eating he did / does when I wrote that..
Wonder where he went??? He might have got his ass handed to him in a hand bag, for all we know!!! :lol:
Reply to RCPilot
- 0 +
i thought he was still in HS, looking for colleges right?
Reply to mrface
- 0 +
Something like that....
Reply to RCPilot
Probably did! LMAO If not, it'll happen sooner or later.
<font color=blue>War</font color=blue> <font color=orange>Eagle</font color=orange>
"Operation Can't Do Nuthin' About It is now in effect!" -Flavor Flav
Reply to Auburn9698
There are 1238 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
