G
Guest
Guest
Archived from groups: microsoft.public.broadbandnet.hardware (More info?)
I just bought a mn520 wireless adapter and it worked for
three days then it started chatering very quickly and
would not make contact with an access point. After working
with a nicrosoft technical fellow in Bombay we were able
to find out that the ID had changed and the adapter could
not find the access point. changes were made and it now
works but the communication chatter still goes on. The
green wireless light flashed alonmg with the chatter and
it can be qite annoying. So, my question is, is the
adapter noise common or may there be a problem?
msavery
stjmss6912@shaw.ca
msavery
stjmss6912@shaw.ca
