Another iPhone 4 Problem?
Last response: in Cell Phones & Smartphones
October 7, 2010 9:00:35 PM
Have a look at this article courtesy of Engadget:
http://www.engadget.com/2010/10/07/apple-afraid-of-a-sh...
Have any Tom's user's who own an iPhone 4 experienced this issue? If so, have you called Apple to see what they had to say about it?
More about : iphone problem
October 9, 2010 10:03:21 AM
I keep mine in a case;therefore,i haven't had any crackes/scratches on the back but if you use it naked then it can scratch easily and will easily break if you drop it few times,that's because of its glass.
Its not a serious issue though IMO,many people keep their phones with a case.
October 11, 2010 5:48:40 PM
I guess then, it is a matter of ensuring the phone is clean (and the case) before putting a case on. It seems to me though that smart/cell phones in general should be to a point where scratches from everyday use should be eliminated. Then again, I'm not a polymer expert;)
October 13, 2010 3:17:20 AM
So far so good for my iPhone4 with no cracks. I did have to get my iPhone3 replaced for what they (Apple) called a pressure crack in the back. They said it happens to users who have the phone in a tight case and keep it in their pants pockets. It happened once and so far it has held up nicely as my 6 yr old's "large iTouch" :)
October 13, 2010 6:41:48 AM
Aside from proximity sensor problems(which I have to test few settings again),I haven't had any problems with the antenna or any cracks at the back(I'm using it with a case though)
October 13, 2010 6:46:35 AM
Yeah... Same here :)
It looks like 4.1 corrected the proximity sensor for me though and the case fixes the antenna (though I choose a cheap one from the Case Program & had to buy a better one :(  )
October 13, 2010 5:28:26 PM
4.1 didn't fix it for me,but i think its a software problem and will be fixed with a new OS.
I'm going to try it without a case and see it it still happens.
October 16, 2010 1:34:10 PM
Does anyone use screen protectors? I mean seriously?
I have back and front screen protectors. If you don't have them, get the $2 back and front kit from monoprice. They are the best. I have tried a few on ebay and some more luxurious $5 ones but most of them either had poor cuts or the oily rainbow on the plastic.
October 16, 2010 1:56:57 PM
No, I don't use a screen protector, as it won't fit my case without cutting it. I used a front one on my iPhone 3G though :)
October 16, 2010 6:27:11 PM
I don't use any screen protectors on my iPhone 4/iPad either because the screen is rather scratch proof(at least with human's hands)
