Archived from groups: microsoft.public.windowsxp.general (More info?)
I have just built a new PC from new components. It boots into BIOS fine and
detects all the drives - SATA HDD and CD. I have set up CD as boot drive,
and installed the XP Pro disc. It immediately puts message "Setup is
inspecting your hardware configuration..." and then just sits there doing
nothing. I have left it for a long time so far but nothing is happening.
This is repeatable. Do I need to do something different eg load drivers from
a floppy or is there a problem with my hardward set up? Anyone able to
assist me?
Is the hdd partitioned and formatted?
Ron Sommer
"Calzone" <Calzone@discussions.microsoft.com> wrote in message
news:07B78DF0-5385-4388-99D5-239E0DF217B3@microsoft.com...
>and
> from
> assist me?
Wouldn't matter, a drive does not need to be partitioned or formatted at
this point of setup. More likely it is that there is a hardware
misconfiguration.
Check jumper settings, reseat cabling, detection settings in the system
BIOS, clocking and frequency (do not overclock).
"Ron Sommer" <rsommer@nospam.ktis.net> wrote in message
newsNsD37XeFHA.1456@TK2MSFTNGP15.phx.gbl...
> Ron Sommer
>>and
>> drive,
>> from
>> assist me?
Thanks. One thing I have noticed is that my mobo, DFi Sli-DR, has an extra
power connector of floppy type. I'd plugged in a spare connector the only
way it would fit. Looking at manual it implies pin one should be +12v, but
connectr will only fit with 5V in that slot. given I have only 1 vga card
and it has its own 6pin power connector, maybe I don't need this connector.
i'll try it. failing that, will putting my old pc's HDD on the new one's ide
allow me to boot, or should it still fail on basis there's a hardware
conflict?
> misconfiguration.
> Best of Luck,
> Rick Rogers, aka "Nutcase" - Microsoft MVP
> http://mvp.support.microsoft.com/ > Associate Expert - WindowsXP Expert Zone
> www.microsoft.com/windowsxp/expertzone > Windows help - www.rickrogers.org >
> > Ron Sommer
> >>and
> >> drive,
> >> from
> >> assist me?
news:3A1FF42C-5436-4E29-83B7-B1ED08C3EC08@microsoft.com...
> extra
> but
> connector.
> ide
> conflict?
>> misconfiguration.
>> Best of Luck,
>> http://mvp.support.microsoft.com/ >> Associate Expert - WindowsXP Expert Zone
>> www.microsoft.com/windowsxp/expertzone >> Windows help - www.rickrogers.org >>
>> > Ron Sommer
>> >>fine
>> >>and
>> >> drive,
>> >> doing
>> >> happening.
>> >> drivers
>> >> from
>> >> to
>> >> assist me?
In article <07B78DF0-5385-4388-99D5-239E0DF217B3@microsoft.com>,
Calzone@discussions.microsoft.com, =?Utf-8?B?Q2Fsem9uZQ==?= says...
> assist me?
>>assist me?
> Are you getting the F6 option to load drivers?
Yea the op probably needs SATA drivers. Just because the BIOS sees the
drive is no guarantee that XP's install routine can.
In article <v_gve.140$JM6.106@trndny05>, John@nowhere.com, John says...
> >>assist me?
> John
Yep, that was my next step/question, but the OP did not mention if the
F6 option even comes up at the bottom of screen..........
Short answer to your question is that I dont see it. The bios screen appears
and disappears so quickly that I don't have time to actually read it. Once
it passes to the boot poage showing irq tables etc, it then immediately boots
from cd, and immediately says "setup inspecting hardware config..." and then
just stops. I could try pressing f6, but at what point would I do this?
> > >>assist me?
> > John
Its a new NF4 SLI board, and the manual clearly states that it has a 24pin
atx power connector, a 4pin 12v connector, an additional HDD type power
connector and a FDD type power connector. In theory it says the last two may
not be entirely necessary especially if you are not running SLI. In any
case, the last FDD type connector is not set up to match the voltage on the
pins on my power supply's FDD power connector, it seems that the 5v and12v
pins are the wrong way round. As best I can tell it shouldall work without
that one connected anyway.
> Hi,
> Where on the board are you seeing this extra power connector? Are you sure
> it's what you think it is?
> > conflict?
> If it's a hardware conflict, it still won't boot.
> Best of Luck,
> > extra
> > but
> > connector.
> > ide
> > conflict?
> >> misconfiguration.
> >> Best of Luck,
> >> http://mvp.support.microsoft.com/ > >> Associate Expert - WindowsXP Expert Zone
> >> www.microsoft.com/windowsxp/expertzone > >> Windows help - www.rickrogers.org > >>
> >> > Ron Sommer
> >> >>fine
> >> >>and
> >> >> drive,
> >> >> doing
> >> >> happening.
> >> >> drivers
> >> >> from
> >> >> to
> >> >> assist me?
1) best place to get help would be a group based on your motherboard; did
you say DFI? They have a newsgroup.
2) The extra power connectors are for the SLI setup, you shouldn't need
them with an ordinary video card. The fact that the cd boots and starts
indicates your power is ok. [perhaps the CD is bad? visually inspect
for any debris or scratchs].
3) Unplug all extra devices until after xp is installed. Have only the
one optical and the one HD plugged in, plus the floppy. [no zips, extra
HDs/Opticals, multi-card readers, any usb attached items, firewire, lan,
etc]. The two drives should be plugged into there "final" interfaces (ie,
don't plan to move them after install).
4) make sure your SATA is configured in the bios correctly. review ALL
your bios settings carefully. particualarly...
5) on an NF4, make sure APIC Mode is true (Adv Prog Interrupt Controller,
not APCI). This enables interrupts above 16, and is necessary to get ACPI
(power mgnt) to work and be detected by xp setup (and have it install the
acpi hal). NEVER CHANGE THIS BACK TO FALSE AFTER SETUP, OR THE BOX WON'T
BOOT.
6) When you do finally get setup to run, you will need to press F6 and
insert a floppy w/ the SATA+RAID drivers on it, even if you are not using
the raid feature. W/ an NForce config, there are TWO drivers you need to
select (in sequence). Check the MB docs, they should make this clear. If
you can't find it, check the nvidia nforce site, there's a doc there that
explains it. You may want to go ahead and dl the latest nforce suite too.
This gets installed after XP is up and working (you'll use bits of it to
make the F6 floppy tho). [The MB should have come w/ this floppy,
really. it should be fine to do the install, then update the nforce w/
latest version.]
