Tom's Hardware > Forum > Computer Peripherals > Webcam > genius webcam installation problem
Forum Computer Peripherals : Webcam - genius webcam installation problem
hello
yesterday I bought a genius videoCAM Trek webcam. I firstly plugged the USB cable and then installed the driver. However I know that I should have done vice versa. Now the computer does not recognize the webcam and I can not use it. Does anyone have an idea about this problem?
Thank you
Sponsored Links
1. Unplug the webcam
2. Uninstall the driver
3. Reinstall the driver
4. Plug in the webcam
That should do it...I think.
Reply to _Morphine_
You should make all as has told "_Morphine_".
I too have installed the genius webcam and in the beginning I too had such problem but I have soon corrected it.
I hope at you will be no such problems and hope that we shall soon talk to you at camwt.com
Reply to natia
I AM HAVING THE SAME PROBLEM RIGHT NOW..
I DID WHAT WAS ADVICED HERE
AND IT STILL DOESNT WORK
ANNY SUGGESTIONS???
Reply to Angelina89
There are 1339 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
