Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Dialup problems - error 6, then error 50 trying to connect
Forum Windows XP : Windows XP General Discussion - Dialup problems - error 6, then error 50 trying to connect
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hello. I am having trouble getting a computer with XP Pro to connect to an
dialup ISP. I set up a manual connection and received the same errors that
were received when using the ISP software. First I get an eror number 6 -
The handle is invalid. Redial and I get an error number 50 - The request is
not supported. I am able to use HyperTerminal to dial my cell phone, so I
know the modem is OK. I have attempted using a selective startup with
startup items not included, but that did not allow the connection to be
completed either. Does anyone know if it is even possible to use a dialup
connection with Windows XP Professional?
Sponsored Links
> to an
> that
> 6 -
> request is
> so I
> be
> dialup connection with Windows XP Professional?
Of course you can use a dialup connection with XP Pro. If you know your
modem works correctly, then there must be a problem with the
information you are entering to connect to the ISP. I would suspect
your username and/or password is incorrect, or perhaps you have the
wrong access numbers. Contact your ISP's tech support for help.
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Reply to Malke
Thank you for your reply Malke. I have tried different access numbers and I
have tried a different username and password that works on a different
system. None of this is working. I have spent quite a bit of time with the
ISP tech support to no avail. That's why I posted my question in the first
place.
"Malke" wrote:
> > to an
> > that
> > 6 -
> > request is
> > so I
> > be
> Malke
> "Don't Panic!"
Reply to Anonymous
- 0 +
> and I have tried a different username and password that works on a
> different
> with the
> first place.
> "Malke" wrote:
>> > connect to an
>> > errors that
>> > number 6 -
>> > request is
>> > phone, so I
Then I'm sorry, but I don't know. Perhaps you have some third-party
firewall that is blocking your connection or perhaps the modem is
flaky. There was no way for anyone to know what you had already done;
that is why putting full information in your first post is a good idea.
If you don't have any third-party software that could be blocking the
modem from dialing out, try swapping out the modem for a known-working
one. If this is not your cup of tea, take the machine to a professional
computer repair shop (not your local equivalent of BigStoreUSA).
Good luck,
Malke
"Don't Panic!"
Reply to Malke
There are 847 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
