I'm building a PC from old parts but have been having serious problems finding a HD that will work.
heres the story behind drive #4 (1st 2 were 1gb and definitely broken, #3 I thought was broken and after OS install it started losing data and crashing).
The drive had win98 installed. I know this drive worked fine in the previous PC it was in. When I install it in this new PC, it is not detected in bios. I have tried a couple different IDE cables. The drive IS powering up.
I then plugged it into the RAID array on this computer. It was detected fine in bios and installed fine in windows 2k. I formatted the drive with NTFS in windows, put it back in the new PC.. still not detected.
Is it possible that this is not a problem with the HD, but instead perhaps the anchient sound, video card, ram, or mobo? The mobo and ram worked fine during their previous use.
thanks for any suggestions.
