Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problems with network card.
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi. I have an XP. All network cards send data, but any of them receives data
( both wired and wireless ). I've runned antispy soft and antivirus soft but
It remains the same. What can I do?.
Thanks.
Sponsored Links
What is your Internet connection device/method ? ADSL/Cable with a
built-in Router/Separate or None ? Have you done an IPConfig/ALL
from a Command Prompt to check the NIC's settings. Can you Ping
the Device or ISP Gateway/DNS Server ? How are you determining
that Packets are being sent, but no return data is received ?
"JP" <aspento_quitar_para_correo_@arrakis.es> wrote in message
news:uJLAckzeFHA.616@TK2MSFTNGP12.phx.gbl...
> data
> but
> Thanks.
Reply to Anonymous
- 0 +
Is ADSL. the IP is correct, and the gateway too. I can't ping to any
computer of my network. I click on network adapter and incoming data appears
anumber that constantly grows but in send data is always 0. It happens in
all netwok cards.
"R. McCarty" <PcEngWork-NoSpam_@mindspring.com> escribió en el mensaje
news:uFxN2pzeFHA.1404@TK2MSFTNGP09.phx.gbl...
> > data
> > but
> > Thanks.
Reply to jp
So you're saying your NIC's are receiving data from the ADSL modem
but no outgoing traffic is occurring ? Are you using the Windows Firewall
or another 3rd-Party firewall program ? Have you logged into the ADSL
modem and checked it's Status page and settings. Is this an initial setup
issue or a new problem that has just started happening ?
news:%23kbrExzeFHA.3616@TK2MSFTNGP09.phx.gbl...
> appears
> all netwok cards.
>> > data
>> > soft
>> > but
>> > Thanks.
Reply to Anonymous
- 0 +
No, in the LAN icon, at activity section it says that had send data but the
receive data is 0...I can't ping any computer of my network, so I can't ping
to ADSL gateway. Thanks.
news:OxXYF2zeFHA.1504@TK2MSFTNGP15.phx.gbl...
> > appears
in
> > all netwok cards.
receives
> >> > data
> >> > soft
> >> > but
> >> > Thanks.
Reply to jp
There are 988 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
