Hello,
I was wondering if someone could tell me what to do next. I have 4-year-old Dell Inspiron 8600. A few months ago, the battery stopped charging and only functions while plugged in.
At first, I replaced the A/C adapter because the light on the original A/C brick wasn't lit anymore when plugged in. When that didn't fix the problem, I bought another battery figuring the original had died and could no longer hold a charge.
After replacing the A/C adapter and battery, it still won't charge. Is there an internal charging unit or something that could be fried? What would one suggest in my situation?
Thank you for suggestions,
Clintox
Sponsored Links
yep u figured it out (an internal charging unit ) which in other words called (the DC Socket) needs replacing.
Reply to cheaptofix
Thank you for the reply. Now I know what to call it and what to look for.
Thanks again,
Clintox
Reply to clintox
i have the same problem like urs. havent been able to figure out the next thing to do with it. did u have to replace the DC socket, or what did u do to fix this problem? thank you.
Reply to kneecase
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Laptop Not Charging Battery
There are 660 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
