6ms, 1500:1 CR (MagicContrast, so probably "Dynamic" ), SPVA panel... all for $359 at Newegg.
This monitor should appeal to those who want a higher quality display... good contrast, color fidelity and viewing angles... not just the "fastest" (though perhaps fast enough), desired by gamers.
To understand the difference between Contrast Ratio and Dynamic Contrast Ratio, suggest you do internet search for explanation. It's too long for here.
Pricey? Compared to cheapo TN panels, I suppose so. For an SPVA panel (which is higher quality, better colors depth, better viewing angle, and therefore more expensive), $359 is quite a good price.
Unfortunately, there's nothing "pro" about that review...
Still waiting.
The model looks good though. Maybe too good to be true.
I failed to find information about the driver issue. Is it Windows only monitor? Or one can adjust brightness/contrast through OSD?
Anyone?
I suppose "pro" is a matter of degree. My definition is a review by someone who regularly reviews so he has comparative knowledge as opposed to a buyer who rates his as "cool".
It's for PC and Mac.
I believe the 970P had no separate OSD. You had to install the MagicTune software to be able to adjust the screen. That may be the case with the 971P, too. I prefer MagicTune to messing with OSD buttons.
Driver issue? I didn't know there was one.
Curiously, Newegg had the 971P (and the other new model, 931C) for a while, now not... and they're not listing them as "out of stock", just not listing them at all. I wonder what gives?
It's for Windows and Mac, one should say Samsung's software is for Windows only...I'm not familiar with Mac, there should be a standart way to change the parameters through DDC...
I just checked for 970P, users actually can control it under Linux through nvidia-settings (nVidia cards only) or DDCcontrol.
That's what I ment with "Driver issue", though I should've used "software issue."
Quote :
I've checked various sites for the 204T (20.1", UXGA version of the 940T, 970P), and it's mostly out of stock. I wonder if Samsung is coming with a 204T replacement with the same type panel as the 971P ??.
971P, the model is not S-PVA panel.
That's panel is just PVA panel.
Same model is selling in Korea as named as CX913P. It's panel is PVA. And also, CX913P model name is for Korea-internal name.
The model is same thing with 971P. (Samsung uses different model name for internal/external product.)
However, you can check the panel type of the 971P from Samsung's homepage.
There is no word like S-PVA in feature information page.
In specification page, it noticed as S-PVA, but it's wrong.
You can check it from Samsung via E-mail. I checked this via email, and Samsung ERMS replied they are wrong. I sent the URL of page contains wrong information to them. However, they did not modified the information still now.
