Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Targus 90W power adapter causing DC jack to burn?
Forum Laptops & Notebooks : General Laptops & Notebooks - Targus 90W power adapter causing DC jack to burn?
I have a Gateway laptop, and its input is 19V 3.42A. Its original AC adapter recently stopped working. So I bought a Targus 90W power adapter to replace the original adapter. It has a rating of 15-24V and 90W max, which I thought would work fine with my laptop. Well tt worked for about 5 hours. Then the DC jack started to have smoke coming out of it, and the laptop stopped charging. :fou:
My question is did my new AC adapter cause the problem? Or is it just a coincidence and my DC jack just went back on its own.
Thank you very much.
Sponsored Links
Likely the adapter. That's what you changed, and that's when the problem occurred. I'd suspect the jack if the notebook stays plugged in for a long time.
Reply to frozenlead
There are 495 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
