Presario r3000 power up
Forum Laptops & Notebooks : General Laptops & Notebooks - Presario r3000 power up
I have a Compaq Presario r3000 laptop that stopped working out of the blue. Now when I hit the power button the power lights flash but it will not power up. Could a bad fan be the problem or is it something else.
Sponsored Links
Disconnect everything you can from the notebook - CD drive, hard disk, battery, one stick of RAM if you have two, any other attached device - and try powering it up.
Reply to frozenlead
- 0 +
tried that and still nothing......Maybe bad stick of memory?
Reply to gryphon
Look up your owner's manual and see if your blinking power light (if it's doing that) is an error code for something. A notebook that doesn't power on usually has larger problems than bad memory.
Reply to frozenlead
- 0 +
I don't think its a error light ....its not really blinking it just acts like its starting to boot up then the light goes out. I'll check tho.
Reply to gryphon
- 1 +
Maybe the power plug on mainboard got dry joints therefore battery was n ot charged anymore and without knowing you have used the unit until the battery went flat and now when you try to power up light is flashing indicating a flat battery whilethe power adapter is plugged for nothing as the power plug is dry jointed. Have to dismantle the unit, inspect the power plug and clean / resolder
Reply to kenzz0
This problem is common for these presario laptops. My last one was an r3360. luckily its plug was fine, but on r3000forums.com it was quite common, as the plug is soldered directly onto the board.
Reply to rpeters83
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Presario r3000 power up
There are 1301 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
