Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > My processor wont run at the right speed.
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hey all, I have an AMD Athlon 2100+ processor, in a ABIT AT7-MAX2 Mother
Board. When I got the computer it was perfect, it ran at the optimal speed
all of the time...then I got a new processor, it was an AMD Athlon 2400...but
didnt work at the right speed...it always fell down to 1777. So I replaced
the original pentium, because I assumed my mother board could not work with
the new processor. Anyway, now my processor runs at 1555, if I go into the
CMOS options from the boot up screen and change the processor speed by the
time windows opens it returns back to 1555.
Also everytime I turn my pc on a little message comes up saying that the CPU
information has been changed and that I should consult the CPU options screen
for details....and I have to press F1 then windows loads normally. Other
than this problem my pc runs perfectly...so I am a little puzzled.
Anyone got any ideas?
Thanks for your time.
Alex
Sponsored Links
this is most definitely a bios settings issue and nothing to do with windows,
point to note 2100+ and 2400+ plus are not the actual processor speeds so
check on amd's website for the actual processor speed and check that, while
you are there find out your settings i.e. multiplier, bus speed etc and you
should then be able to set ip up correctly in your bios
there are no problems, just challenges
> Alex
Reply to steve
> Mother Board. When I got the computer it was perfect, it ran at the
> optimal speed all of the time...then I got a new processor, it was an
> AMD Athlon 2400...but didnt work at the right speed...it always fell
> down to 1777. So I replaced the original pentium, because I assumed
> my mother board could not work with the new processor. Anyway, now
> my processor runs at 1555, if I go into the CMOS options from the
> boot up screen and change the processor speed by the time windows
> the CPU information has been changed and that I should consult the
> CPU options screen for details....and I have to press F1 then windows
> loads normally. Other than this problem my pc runs perfectly...so I
> Alex
Your post makes no sense whatsoever.
1) WTF does "I replaced the original pentium" [/sic/] mean? You have
*NEVER* had a Pentium chip - Pentium is a trademark applied to certain
*Intel* CPUs, you've never had an *Intel* CPU in that box, you've had AMD
CPUs. A Pentium CPU will *NOT* fit in a board designed to accept an Athlon
CPU.
2) Nor has this anything to do with Windows, it is a BIOS issue and the
BIOS has nothing whatsoever to do with the operating system. The simple
answer is you have the FSB set incorrectly.
3) It really irks me when people refer to the BIOS as "the CMOS" - the
two terms are mutually exclusive and *NOT* interchangeable. It just shows
your ignorance: -
CMOS: - Complementary Metal Oxide Semiconductor, and is the name appiled to
the chip where the BIOS information is stored.
BIOS: - Basic Input Output System - this is where the basic information
about your computer is, when you save, it is *written* to the CMOS.
However, you do *NOT* "enter the CMOS".
4) Suggest that you need to change the multiplier. AthlonXP chips are
locked at a multiplier of 15, therefore you need to make sure the FSB is set
to 133 (133 x 15 = 2000 give or take (it's actually 1995, but the FSB has to
be a whole number; you cannot set it to 133.33 recurring)).
Reply to Anonymous
"Miss Perspicacia Tick" <test@test.com> wrote in message
news:8Mtwe.128$L42.76@fe07.highwinds-media.phx...
> > Alex
> CPU.
> your ignorance: -
to
Actually, he's entering data into the cmos memory via the bios setup. He
skipped some basic grammar to get across an idea. Most understood it,
including yourself obviously.
CMOS (complimentary metal semiconductor) describes the type of electronics
material the bios setup memory is used in its manufacture. Calling this
specific use memory "cmos" in itself is a very inaccurate term. This irks
me, but I tolerate it because that's what the status quo uses to communicate
the idea with.
As is "entering the cmos" transcending entering the bios setup, changing or
whatever, and saving. They mean the same thing by virtue of some people's
perceptions. And used as a shortcut of words to describe the same idea.
Even those that understand the difference between the words "bios", "bios
setup", and "cmos" may use the term "enter the cmos".
set
to
Reply to Anonymous
On Wed, 29 Jun 2005 01:29:04 -0700, "Al"
>Alex
What is the problem? AMD athlon chips are not numbered by their
speed. The 2100 or 2400 do not mean that they run at that speed.
They actually run at much slower speeds. The 1555 and 1777 you are
seeing is right about right for those 2 chips.
Reply to Anonymous
>> an AMD Athlon 2400...but didnt work at the right speed...it always
>> fell down to 1777. So I replaced the original pentium, because I
>> assumed my mother board could not work with the new processor.
>> Anyway, now my processor runs at 1555, if I go into the CMOS options
>> from the boot up screen and change the processor speed by the time
>> windows loads normally. Other than this problem my pc runs
>> Alex
You're talking bollocks too. An Athlon 2400+ has a clock speed of 2GHz. The
2100+ has a clock speed of 1733. As I stated he had the FSB incorrectly
set - it should have been set to 133.
Reply to Anonymous
We all understood but she always has to write extremely angry, negative
comments in response to postings here. Search for her past postings and you
will see. The majority of her responses denegrate and insult people who are
just trying to get some help here.
That's just like my opinion, Man........
> > > Alex
> > CPU.
> > your ignorance: -
> to
> the idea with.
> set
> to
Reply to Anonymous
- 0 +
What really "irks" me Miss Tick is your continual carping at people
about the way they post with absolutely no help for the poster to the
original problem.
Why don't you just avoid reading the newsgroup if it irks you so much?
Do you go to other newsgroups and perform the same critical ritual?
Isn't there an alt.poor. english newsgroup you can monitor and post
in?
On Wed, 29 Jun 2005 10:23:05 +0100, "Miss Perspicacia Tick"
>> Alex
>CPU.
>your ignorance: -
Reply to Scott
These links show the real speed and rated speed of each processor.
http://www.cpu-world.com/CPUs/K7/A [...] DMT3C.html
http://www.cpu-world.com/CPUs/K7/A [...] DKV3C.html
This one for the 3200+ shows and actuall speed of 2200.
http://www.cpu-world.com/CPUs/K7/A [...] DKV4E.html
AMDs are made for overclocking so the numbers of the CPU don't necessarily
correlate with actual speed. It's kind of misleading in my opinion.
Especially, since you have to overclock the heck out of them to approach the
speed indicated by the CPU model #. And if you do overclock that far, you
need to hook up the CPU to your car's cooling system so it doesn't fry from
all the heat.
> >Alex
Reply to Anonymous
Yo Dude, just go ur BIOS and check you CPU settings you have to over clock it
youre self or there shoule be some auto mode for ur CPU so that it can adjust
it self to its own right settings
> all the heat.
> > >Alex
Reply to Anonymous
news:9eAwe.146$DN.44@fe01.ams...
Abit motherboards have "Soft Menu."
Everytime a major change in the computer is made, like flashing the BIOS . .
.. it gives a message that your CPU is not running at the correct speed. It
is annoying . . . but you will get use to it.
This is for the original poster: Make sure you are familiar with the Abit
motherboard. Read the manual on how to use the "Soft Menu." If you are
already familiar on how to use the "Soft Menu" . . . make sure you are not
in the "over clocking setting."
Orinello
Reply to Anonymous
On Wed, 29 Jun 2005 17:44:46 +0100, "Miss Perspicacia Tick"
Sorry you are right. I forgot that they did have higher clock speeds
till they came out with the barton chips then they lowered the clock
speeds on the chips. For instance the 2500+ has a clock speed of only
1883
Reply to Anonymous
There are 738 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 13:08 OvrClkr won the Overclocking badge
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
