Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > 98SE to XP home..help please
Archived from groups: microsoft.public.windowsxp.general (More info?)
Nervously I have decided to install Win XP Home on my single desktop, which
had win98se on.
I wish to do a clean install.
I have done FDIDISK, rebooted & FORMATTED H/D by "Format c: /s" method,
after remove old partitions.....that's how I installed 98se previously.
I beleive I have made a big mistake as I am unable to run SETUP on the XP CD
from dos!!!!!...I have rebooted to "cd support" on floppy drive.
Currently when I reboot without the floppy in the screen shows dos the
prompt, but unable to access any other drive....The directory of c: prompt
shows "command com" 1 file(s).
I am posting here now using my laptop (win98se), but obviously able to
"surf", hence I may obtain help this route.
I have no CD writer in laptop but have a cd rom drive & floppy drive.
Hope I have explained my dilema ok???
Tel
Sponsored Links
> which had win98se on.
> method, after remove old partitions.....that's how I installed 98se
> previously.
> the XP CD from dos!!!!!...I have rebooted to "cd support" on floppy
> drive.
> prompt shows "command com" 1 file(s).
> Tel
And the reason you cannot change the BIOS settings to boot from the CD drive
is...?
Reply to Anonymous
- 0 +
with xp you do not install from dos, change your bios to boot from cd, place
xp cd in drawer, boot pc when it boots from the cd follow the instructions
there are no problems, just challenges
> > previously.
> > drive.
> > Tel
> is...?
Reply to steve
Your computer is good enough for XP?
http://www.microsoft.com/windowsxp [...] fault.mspx
Will all of your programs run on XP?
I seriously doubt a 98SE computer will update to XP.
Ron Sommer
"tel" <terrybetts11138@hotmail.com> wrote in message
news:d9ts57$a60$1@nwrdmz03.dmz.ncs.ea.ibs-infra.bt.com...
> which
> had win98se on.
> CD
> Tel
Reply to Anonymous
- 0 +
> Ron Sommer
Horsepucky. I have an HP Pavilion that sports an AMD 800 Mhz with 256MB RAM
that came with 98SE preinstalled on it and XP works wonderfully on it. Not
only that, XP had the all the drivers.
BTW, there is no such thing as a "98SE computer".
Alias
>> which
>> had win98se on.
>> CD
>> prompt
>> Tel
Reply to Alias
which
> had win98se on.
CD
> Tel
Rather than go through the hassle of making the 6 XP boot floppies, here's a
one floppy route that uses the method you're trying to use and are used to:
http://freepctech.com/pc/002/files010.shtml
If your PC allows boot from CD via bios setup, the XP CD is bootable. Then,
the above is not needed.
Reply to Anonymous
You do not format your drive C: first. XP install will take care of that!
XP does not use DOS to boot. Use FDISK again and revome the partiton(s) and
then boot the XP CD.
If the XP CD is an Upgrade CD, you will need your Win98SE CD close by. The
Upgrade will need to check the Win98SE CD in order to see if you qualify for
the Upgrade. Also, never get rid of your Win98SE CD! It will be needed
each time you re-install XP.
> which
> had win98se on.
> CD
> Tel
Reply to Anonymous
"Alias" <aka@[notme]maskedandanonymous.org> wrote in message
news:eMQxVOKfFHA.484@TK2MSFTNGP14.phx.gbl...
>> Ron Sommer
> RAM that came with 98SE preinstalled on it and XP works wonderfully on it.
> Not only that, XP had the all the drivers.
> Alias
Glad that you had the right hardware to upgrade.
Ron Sommer
Reply to Anonymous
You cant run a windows file from dos. Go the the i386 folder on the cd
and run the dos setup program, aka winnt.exe
http://www.bootdisk.com/
Reply to Anonymous
That is one good thing about big brand pcs ie XP will usually have the
drivers for the older big brand systems.
Reply to Anonymous
- 0 +
Thank you ALL
I ended up doing a Clean re-install of Win98SE, then upgraded to XP Pro
OKKKKKKK.
Pleased I "went for it now"......
Tel
which
> had win98se on.
CD
> Tel
Reply to terry
> had win98se on.
> Tel
Simply boot from the WinXP installation CD. You'll be offered the
opportunity to delete, create, and format partitions as part of the
installation process. (You may need to re-arrange the order of boot
devices in the PC's BIOS to boot from the CD.)
HOW TO Install Windows XP
http://support.microsoft.com/defau [...] -us;316941
http://www.michaelstevenstech.com/cleanxpinstall.html
http://www.webtree.ca/windowsxp/clean_install.htm
Bruce Chambers
Help us help you:
http://dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
You can have peace. Or you can have freedom. Don't ever count on having
both at once. - RAH
Reply to Anonymous
- 0 +
How about "did you know that you can change your boot order in the BIOS"?
That would be a HELPFUL answer, but that escapes a lowly troll like
yourself, doesnt it?
"Miss Perspicacia Tick" <test@test.com> wrote in message
news:WIuwe.3343$gu6.2925@fe03.ams...
>> previously.
>> drive.
>> Tel
> drive is...?
Reply to juy
- 0 +
Scum reply
"jUy" <Npo@lJJ.com> wrote in message
news:OZJwHC0fFHA.3256@TK2MSFTNGP12.phx.gbl...
> >> previously.
> >> drive.
> >> Tel
> > drive is...?
Reply to terry
There are 589 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
