Up until recently I have been using CRT monitors exclusively.
When I bought a new computer I thought it was time to try a LCD monitor.
I read various tests/reviews/opinions on what would possibly be the best monitor for my use. (Which is primarily gaming)
After reading about 12 different tests where Nec Multisync 90gx2 ranked in the top 3 in every single one of them I thought this would be the one for me.
So I got the monitor and noticed that the top part of the screen was much darker than the lower part. (Viewed from a "normal" angle obviously)
And the lower part had very "washed out" colors.
I replaced the monitor right away thinking it was something wrong with it.
... but to my surprise the new one had the exact same flaw.
I then checked with a few friends that had different LCD monitors than the one I bought... and theirs had the same flaw aswell.
Do all LCD monitors have this "feature" ?
If yes... then why on earth do people just accept that the "new standard" in monitors are much worse than the old one?
If no... what LCDs does NOT have this flaw? And what causes this flaw in the first place?
For those out there that might be interrested in testing this on their own monitor... the flaw is mostly visible on "dark warm colors".
The easiest way to test this is:
Go to Desktop properties... select None as background picture... select burgundy (2nd col. just below black) or dark green (2nd col. 2 down from black) as background color and Apply.
If you have the flaw you will typically see that opposing corners have different "shades" of the selected color... as an example.. top left will look darker than bottom right etc.
For those of you that have problems with seeing certain colors well.. it also works with dark blue... but its much harder to see the difference.
Any input on this topic is welcome as Im still wondering if I should try replacing my monitor again, or just accept the loss and buy a new CRT instead.
Sponsored Links
Newegg buyers have not complained of this. Any chance it could be your video card... is it old? VGA/DVI cable? Do you have "onboard" video? Do you have the latest video driver installed?
Just fishing....
Reply to Hose
Tested on a GF 7800 GTX and a Radeon 9800 Pro card.
Tested with 4 different cables both new and old standard.
Tested with 3 different driver-versions on the Geforce card
Tested with 2 different driver-versions on the Ati card.
All tests have the same result.
Also tested my old CRT monitor on this card, and it shows no color-difference from top to bottom.
Reply to SleepyOne
- 0 +
My Dell 2405FPW out of the box was too bright and colors were not adjusted correctly, but it was easy to calibrate, and looks excellent now.
I read an article on the newer LCD's, that color calibration was much better out of the box... creating a better mass user experience, for those who are not aware.
Reply to RichPLS
The flaw you are referring to is the viewing angle issue. Although LCDs list insanely high viewing angles, this number is not accurate. Even very small angles can produce small differences in color, which if you are editing images this can be a problem (even very small differences). The panel you probably looked at was a TN panel. P-MVA panels are supposed to be better with viewing angles, but still not quite perfect in producing a consistant color across the whole image. PVA and S-IPS are supposedly even better.
[code:1:91bf73d955]If yes... then why on earth do people just accept that the "new standard" in monitors are much worse than the old one?[/code:1:91bf73d955]
Possible reasons:
[*:91bf73d955] Because thin monitors look neat -- and I'm not referring to the picture quality.
[*:91bf73d955] Because it's the new technology
[*:91bf73d955] Because somebody else got one
[*:91bf73d955] Nobody makes CRTs anymore, so you have to buy refurbished or used or hunt around for a new one.
[*:91bf73d955] Because they only sell LCDs in the stores (except for 17" curved screen Compaq CRTs)
[*:91bf73d955] Manufactuer's choice: it is cheaper to produce LCDs
[*:91bf73d955] Because LCDs are now cheaper to buy than a similarly sized new CRT.
[*:91bf73d955] Because LCDs are sharper due to the digital signal and the way pixels are
[*:91bf73d955] Because LCDs have no flicker and thus, theoritically may reduce eyestrain
[*:91bf73d955] LCDs can have higher contrast ratios
Now, for the bad:
[*:91bf73d955] Matte finish LCDs are bad for image editing because the matte finish scatters light causing large areas of a single color to not look completely solid -- bad for image editing.
[*:91bf73d955] If you go for the glossy finish, then these panels have a reputation for having issues with getting colors right; though it doesn't appear to be that bad according to tests. Also a glossy finish supposedly reflects background light, and the reflection is supposedly not good for your eyes.
[*:91bf73d955] All LCD monitors currently sold (no matter how low the response time) has blurring. CRT monitors have nearly 0 blurring in fast motion. Compared to a CRT, this is absolutely abysmal.
[*:91bf73d955] LCD monitors look bad at the non-native resolution when using the desktop; though in games they look fine at non-native resolutions.
[*:91bf73d955] LCD monitors have issues with viewing angles. Althoughy many specify a high viewing angle, the fact is that when you are image editing you need 0 variation in color to do things accurately; however, even slight angles on LCD monitors can cause a small shift in color (though it may not be a large shift that many other people would notice). This issue is present even in P-MVA panels; I do not know about S-IPS or PVA from experience.
[*:91bf73d955] LCD monitors, even with a small pixel pitch still display a screen door effect that is noticeable from time to time.
So, in summary, LCD monitors have issues with displaying good images and fast motion. Basically LCD monitors do not excell at anything except producing a sharp flicker free high contrast image and being light and thin. On the other hand, CRTs excell at displaying good images and fast motion. So, why are we getting rid of CRTs?
Reply to KevinAr18
Quote :
I just got a BenQ FP93GX and the colors seem off abit. What is the best way to calibrate the colors and brightness. Mine to was way too bright out of the box. Any help would be appreciated.
Reply to cptblackeye
- 0 +
LCD displays do not have higher contrast ratios than CRTs.
The most evident proof of that is their inability to produce true blacks. In a CRT or Plasma display that is obtained by not activating a dot(s), whereas an LCD has to block the backlight (not to mention "leaked light" from surrounding dots).
Up to this date, there isn't a method to effectively do that. And this problem affects also color accuracy on LCDs. Much has been done in this aspect (and with very noticeable results, I may say), but LCDs still fall behind CRTs regarding contrast ratio.
Edited for typo.
Reply to BMFM
- 0 +
Quote :
The most evident proof of that is their inability to produce true blacks. In a CRT or Plasma display that is obtained by not activating a dot(s), whereas an LCD have to block the backlight (not to mention "leaked light" from surrounding dots).
In a practical sense, I think you are correct. However, LCD makers "creatively" claim high Contrast Ratios based upon very bright whites (darker blacks would be soooo much better)... usually so bright we have to tone them down to avoid burning our brain!
Reply to Hose
- 0 +
True. They measure the contrast ratio for their displays based on the difference between the brightest white and deepest black.
That's just like average response time when they com up with that gray-to-gray BS. Manufacturers are always hyping the specifications for their products, even creating "standards" for their convenience.
Reply to BMFM
Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > LCD Color problems.
There are 1246 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
