Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > Loading program problem, Please Help!
Forum Windows XP : General Discussion Loading program problem, Please Help!
Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi,
I have XP Home. I am suddenly unable to open Word. It stalls when opening,
nothing works to get it working again. Excel works fine as does all the
other programs. I have tried deleting office but again it stalls when
trying. I have tried re-installing office, but again, it installs the
installation files then Windows installer says 'Preparing to install....'
and nothing happens I just get the egg timer on screen. I have updated and
run Symantec antivirus, Spybot and Ad-aware. All find nothing relevant.
I am totally stuck and can't seem to find anything relevant on Google
either.
Please help.
Lenny
Reply to Anonymous
Just a quick update. Word works when started in safe mode!
Any thoughts?
Lenny
"lenny" <lenny1097@hotmail.nospam.com> wrote in message
news:42c3de91$0$19741$cc9e4d1f@news.dial.pipex.com...
> Hi,
> either.
> Please help.
> Lenny
Reply to Anonymous
Two suggestions, First open Excel, Click Help, then "Detect & Repair".
Have your installation disk handy. Also while in Help, click About and
note the Service Pack Level. Then go to Office Update and get all the
available patches for your Office install. You neglected to mention the
version of Office you use. Office Update only works for versions going
back to Office 2000.
Click the "Check for Updates" at:
http://office.microsoft.com/en-us/ [...] fault.aspx
> Hi,
> either.
> Please help.
> Lenny
Reply to Anonymous
Hi
Search in Windows Explorer for a file named normal.dot. Delete it, then try
to open MS Word again.
Will Denny
MS-MVP Windows Shell/User
Please reply to the News Groups
news:42c3e080$0$19762$cc9e4d1f@news.dial.pipex.com...
> Any thoughts?
> Lenny
>> Hi,
>> opening, nothing works to get it working again. Excel works fine as does
>> all the other programs. I have tried deleting office but again it stalls
>> when trying. I have tried re-installing office, but again, it installs
>> the installation files then Windows installer says 'Preparing to
>> install....' and nothing happens I just get the egg timer on screen. I
>> have updated and run Symantec antivirus, Spybot and Ad-aware. All find
>> nothing relevant.
>> either.
>> Please help.
>> Lenny
Reply to Anonymous
....And i have noticed that there are two WINWORD.EXE in Processes. I am
unable to close either down.
Reply to Anonymous
- 0 +
lenny wrote:
> Hi,
> does all the other programs. I have tried deleting office but again
> it stalls when trying. I have tried re-installing office, but again,
> it installs the installation files then Windows installer says
> 'Preparing to install....' and nothing happens I just get the egg
> timer on screen. I have updated and run Symantec antivirus, Spybot
> either.
> Please help.
> Lenny
This is from another post from some time ago that I saved.
Will, I hope you don't mind me using this? If you do just say so and it
won't happen again.
Will Denny
1/30/2005 8:16 PM PST
Re: Word
In: microsoft.public.windowsxp.help_and_support
Hi
Close Word, open Windows Explorer and search for a file named 'normal.dot',
then delete it. See if you can open your files then.-
Will Denny
"Ron" <Ron@discussions.microsoft.com> wrote in message
news:356569AF-69AB-4612-9E18-907F1D70E9CA@microsoft.com...
> Why can't I open my word files any more? It keeps saying that the files
> are
> not available. And when I try to close word it says the file normal
> already
> exists do you want to replace it. No matter which I choose it still won't
> work
Look here for the normal.dat file
C:\Documents and
Settings\yourusername\Application Data\Microsoft\Templates
and find the file Normal.dot
This link may also be of some help
http://www.word.mvps.org/index.html
Mike Pawlak
Reply to map
Hi all,
I deleted normal.dot but am still unable to open Word (Office 2000) I have
then opened Excel and tried to repair from the help menu but again it stalls
on 'please wait while windows configures Microsoft Office 2000 Premium.
Any other ideas?
Cheers
Lenny
"MAP" <mikepawlak2REM@OVEhotmail.com> wrote in message
news:uUjqT6WfFHA.3124@TK2MSFTNGP12.phx.gbl...
> lenny wrote:
>> Hi,
>> either.
>> Please help.
>> Lenny
> won't happen again.
> Will Denny
> Re: Word
> Hi
> 'normal.dot',
> Will Denny
>> are
>> already
>> work
> C:\Documents and
> Mike Pawlak
Reply to Anonymous
- 0 +
> am unable to close either down.
A simple reboot will close them.
Mike Pawlak
Reply to map
Reboot, make sure no Office apps are running. Put your Office CD
in the drive, it should Autoplay to setup. Take the Add/Remove
components option. Uncheck Word and then let Office remove it
from your install. Then reboot again and reverse the process. Sounds
like something is corrupted or missing. Once you get Word re-installed
go to Office Update and get all the Service Packs/Updates for it.
To preclude something in your profile affecting it, I would use the
Administrator account (If Pro) or create a new Administrative account
and log in to it to perform these modifications.
Are you reasonably sure your system if free of "Baddies" ?
news:42c3edb6$0$19708$cc9e4d1f@news.dial.pipex.com...
> Hi all,
> stalls on 'please wait while windows configures Microsoft Office 2000
> Premium.
> Any other ideas?
> Cheers
> Lenny
>> lenny wrote:
>>> Hi,
>>> either.
>>> Please help.
>>> Lenny
>> won't happen again.
>> Will Denny
>> Re: Word
>> Hi
>> 'normal.dot',
>> Will Denny
>>> are
>>> already
>>> won't
>>> work
>> C:\Documents and
>> Mike Pawlak
Reply to Anonymous
I have also tried deleting another unrelated program from 'Add or Remove
Programs' and all I get is the 'Windows Installer' Preparing to remove...
and the egg timer. Maybe it isn't anything to do with Office?
Cheers
Lenny
> Hi all,
> Premium.
> Any other ideas?
> Cheers
> Lenny
>> lenny wrote:
>>> Hi,
>>> either.
>>> Please help.
>>> Lenny
>> won't happen again.
>> Will Denny
>> Re: Word
>> Hi
>> 'normal.dot',
>> Will Denny
>>> are
>>> already
>>> won't
>>> work
>> C:\Documents and
>> Mike Pawlak
Reply to Anonymous
Yes I am positive that there are no "Baddies" on the computer. This is a
work laptop and I am not in the office where this version on Office is
available. I have 2003 with me though. Is there anything that I can do to
delete the 2000 version? I have tried but with no luck.
Lenny
"R. McCarty" <PcEngWork-NoSpam_@mindspring.com> wrote in message
news:u3QzXUXfFHA.268@TK2MSFTNGP15.phx.gbl...
>> Hi all,
>> have then opened Excel and tried to repair from the help menu but again
>> it stalls on 'please wait while windows configures Microsoft Office 2000
>> Premium.
>> Any other ideas?
>> Cheers
>> Lenny
>>> lenny wrote:
>>>> Hi,
>>>> either.
>>>> Please help.
>>>> Lenny
>>> won't happen again.
>>> Will Denny
>>> Re: Word
>>> Hi
>>> 'normal.dot',
>>> Will Denny
>>>> files
>>>> are
>>>> already
>>>> won't
>>>> work
>>> C:\Documents and
>>> Mike Pawlak
Reply to Anonymous
2003 should update/retain options over the 2000 version. Your
comment about other installer(s) leads me to believe you may
have other issues. I would go slowly, as this maybe one of those
"Quirks" that the more you do, the worse it will become".
news:42c3f228$0$19704$cc9e4d1f@news.dial.pipex.com...
> Lenny
>>> Hi all,
>>> Premium.
>>> Any other ideas?
>>> Cheers
>>> Lenny
>>>> lenny wrote:
>>>>> Hi,
>>>>> either.
>>>>> Please help.
>>>>> Lenny
>>>> won't happen again.
>>>> Will Denny
>>>> Re: Word
>>>> Hi
>>>> 'normal.dot',
>>>> Will Denny
>>>>> files
>>>>> are
>>>>> already
>>>>> won't
>>>>> work
>>>> C:\Documents and
>>>> Mike Pawlak
Reply to Anonymous
Have all the ideas dried up then? I will try anything, the only problem is
everything that I try doesn't seem to work!
news:42c3f0b7$0$19721$cc9e4d1f@news.dial.pipex.com...
> Cheers
> Lenny
>> Hi all,
>> Premium.
>> Any other ideas?
>> Cheers
>> Lenny
>>> lenny wrote:
>>>> Hi,
>>>> either.
>>>> Please help.
>>>> Lenny
>>> won't happen again.
>>> Will Denny
>>> Re: Word
>>> Hi
>>> 'normal.dot',
>>> Will Denny
>>>> files
>>>> are
>>>> already
>>>> won't
>>>> work
>>> C:\Documents and
>>> Mike Pawlak
Reply to Anonymous
- 0 +
http://www.microsoft.com/office/co [...] g=en&cr=US
Mike Pawlak
> problem is everything that I try doesn't seem to work!
>> Remove Programs' and all I get is the 'Windows Installer' Preparing
>> to remove... and the egg timer. Maybe it isn't anything to do with
>> Office?
>> Cheers
>> Lenny
>>> Hi all,
>>> I have then opened Excel and tried to repair from the help menu but
>>> again it stalls on 'please wait while windows configures Microsoft
>>> Any other ideas?
>>> Cheers
>>> Lenny
>>>> lenny wrote:
>>>>> Hi,
>>>>> as does all the other programs. I have tried deleting office but
>>>>> again it stalls when trying. I have tried re-installing office,
>>>>> but again, it installs the installation files then Windows
>>>>> installer says 'Preparing to install....' and nothing happens I
>>>>> just get the egg timer on screen. I have updated and run Symantec
>>>>> Google either.
>>>>> Please help.
>>>>> Lenny
>>>> and it won't happen again.
>>>> Will Denny
>>>> Re: Word
>>>> Hi
>>>> 'normal.dot',
>>>> Will Denny
>>>>> files
>>>>> are
>>>>> normal already
>>>>> still won't
>>>>> work
>>>> C:\Documents and
>>>> Mike Pawlak
Reply to map
thanks MAP,
I have moved the problem over to that group.
I will keep an eye on this one though incase there are any other ideas.
Lenny
P.S. Thanks for the swift responses.
news:%233EpiGYfFHA.4044@TK2MSFTNGP10.phx.gbl...
> Mike Pawlak
>>> Office?
>>> Cheers
>>> Lenny
>>>> Hi all,
>>>> Any other ideas?
>>>> Cheers
>>>> Lenny
>>>>> lenny wrote:
>>>>>> Hi,
>>>>>> Google either.
>>>>>> Please help.
>>>>>> Lenny
>>>>> Will Denny
>>>>> Re: Word
>>>>> Hi
>>>>> 'normal.dot',
>>>>> Will Denny
>>>>>> files
>>>>>> are
>>>>>> normal already
>>>>>> still won't
>>>>>> work
>>>>> C:\Documents and
>>>>> Mike Pawlak
Reply to Anonymous
Have you tried booting into safe mode and doing the uninstall?
Reply to Anonymous
Yes RA, I have tried that but i get a message that say 'the windows
Installer Service could not be accessed. This can occur if you are running
Windows in safe mode.......
Is there another way of uninstalling in safe mode?
"RA" <none> wrote in message news:uFEFsQYfFHA.2840@tk2msftngp13.phx.gbl...
Reply to Anonymous
I would go to Event Viewer & Clear both the System & Application
Event logs. Then reboot and check each one for Errors (Red Icons).
Post back here, any Event ID#'s that are found
Yes, the Installer service won't be running in Safe Mode. You won't
be able to access the Office .msi package while in Safe mode.
What I might try is go to MSConfig.Exe and "Temporarily" uncheck
all Startups and boot to normal mode and attempt your uninstall. This
will effectively turn off some Security - So unplug your Ethernet or
don't connect to the web while doing this.
Otherwise my only other suggestion would be to try and find someone
who might do a Remote Assistance session to help you out.
news:42c40c80$0$19704$cc9e4d1f@news.dial.pipex.com...
Reply to Anonymous
news:O9t9JhYfFHA.460@TK2MSFTNGP09.phx.gbl...
Events to follow
Thanks
I have tried this and it starts OK but when 'Gathering required
information...' it gets to 3 green bars and then hangs again.
>> running Windows in safe mode.......
Reply to Anonymous
There are 1550 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 13 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
