Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > Are you having the same problem with LG L204WT?
Forum Computer Peripherals : Flat Panels/ LCDs - Are you having the same problem with LG L204WT?
Hi Bought the L204WT a few weeks ago and worked lika a charm until,
the DVI connection suddenly didn't work and the VGA input couldn't handle hig resolutions so I went back to the store with it and got it back two weeks later.
and so just now a week later the same problem appeard.
what is wrong here?
Does some one else experience the same problem and what is the solution?
Am I doing something wrong?
Reguards
Robert
Sponsored Links
There are 506 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
