help with choosing LCD
Forum Computer Peripherals : Flat Panels/ LCDs - help with choosing LCD
I have a working monitor right now but it's starting to get a little old and is developing a little line that runs down it. I don't know much of anything about LCD's but I try to keep my eyes open for deals on them. I've come across two good deals. Do you guys think you could compare these two for me and help me figure out which one would best suit my needs? Thanks.
1. http://www.newegg.com/Product/Prod [...] 6824116014
this is 156 after the rebate.
2. http://review.zdnet.com/HANNS_G_HC [...] 87463.html
I can get that for 109 after rebate.
I just built a new computer thats primarily designed for gaming. Should I pick up either one of these, or just wait till I have a little more money and get something better? Thanks.
Sponsored Links
The clear winner of the two is the Viewsonic. I've never even heard of the other brand. the pixel response time is also better for the Viewsonic which is important for gaming. Enjoy your purchase!
Reply to digitaldoc
- 0 +
Quote :
Au contraire.... the Viewsoic is not "the clear winner".
The Hanns-G has significantly better customer reveiws at Newegg, there is a significant price difference, and we all know that maker's "response time" claims can't be trusted.
Reply to Hose
- 0 +
Quote :
"... I just built a new computer thats primarily designed for gaming. Should I pick up either one of these, or just wait till I have a little more money and get something better? Thanks.
If you want to be sure you're getting a good one for gaming, save your money a bit longer, then check out the Viewsonic VX922 and Samsung 931C.
Reply to Hose
Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > help with choosing LCD
There are 592 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
