Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > XP Printer-related problem
Forum Windows XP : General Discussion XP Printer-related problem
Archived from groups: microsoft.public.windowsxp.general (More info?)
Perhaps this should go to an HP NewsGroup - is there such a thing?
I'm trying to help a friend who has visual problems. He just got a WinXP
computer (he had Win98 before). He has an old HP printer/scanner/copier
combo. When he first tried to hook it up to the XP an HP tech person on the
phone said it wouldn't work with XP. But he kept trying on his own and
finally got it installed and working. However, now it prints in reverse
order, i.e pages 3-2-1 rather than 1-2-3 as it did with his Win98 printer.
I have an HP printer (not a combo) myself that gives the option of reversing
that order, but he said he didn't have to choose an option previously to
print 1-2-3. Does anyone have any suggestions and/or other NewsGroup where
I can find help for him?
Reply to Joy
Joy, go to www.hp.com and you can type in the make a model number of
the combo and see if they have a
new XP driver for it. Also, you can check for any info.
"Joy" <joymp2@bellsouth.net.NO_SPAM> wrote in message
news:emxKjsZfFHA.2444@tk2msftngp13.phx.gbl...
> the phone said it wouldn't work with XP. But he kept trying on his own
> and finally got it installed and working. However, now it prints in
> reverse order, i.e pages 3-2-1 rather than 1-2-3 as it did with his Win98
> printer. I have an HP printer (not a combo) myself that gives the option
> of reversing that order, but he said he didn't have to choose an option
> previously to print 1-2-3. Does anyone have any suggestions and/or other
> NewsGroup where I can find help for him?
Reply to Anonymous
I don't have an HP printer any longer but I do remember their settings
included a "Collate" setting. If enabled, the pages print in reverse order
so that the document is in the correct order when you lift it out the
printed sheets. Uncheck the settings if you want to print page 1-2-3 and
then manually collate.
Sharon F
MS-MVP ~ Windows Shell/User
Reply to Anonymous
HP refers to the combination printer/copier/scanner as a PSC. Have the 750
version. Was told it would not work in XP with the driver CD that came with
it.. I went to HP's website, there I found the XP driver package for this
PSC, and also requested the updated printer software on CD. Of which I
received. The PSC works fine in XP.
You have to uninstall both the driver, and the other HP software related to
the copying and scanning first, before installing the new software package.
That is, if you made the mistake of installing the former software first.
The problem you mentioned seems like a user related option in the printer
properties though. Not a driver problem.
the
reversing
where
Reply to Anonymous
If you go the the printer properties (layout tab) there is a page order
setting that can be selected, front to back or back to front.
what ever the default setting for that printer is what you will get, but it
can always be changed.
"Lil' Dave" <spamyourself@virus.net> wrote in message
news:%23VyqCxjfFHA.3160@TK2MSFTNGP10.phx.gbl...
> 750
> with
> to
> package.
> the
>> printer.
> reversing
> where
Reply to Anonymous
- 0 +
Thanks, everyone. I'm copying these replies and sending them on to him. He
needs to wait for someone who can help him visually with trying these
suggestions. (I'm not in his town at this time.)
Reply to Joy
- 0 +
iam having the same problem! my printer prints in reverse. it doesnt do it
when i go to wordpad or any of my other programs that i try to print from. it
only does it when i try to print something from the internet! which is weard!
can somebody please help me with this? i even downloaded the latest harddrive
and still does it?
Denise
Reply to Denise
- 0 +
ohh excuse me i meant to say i dowmloaded the lates drivers from my hp......
> and still does it?
> Denise
Reply to Denise
- 0 +
> do it when i go to wordpad or any of my other programs that i try to
> print from. it only does it when i try to print something from the
> internet! which is weard! can somebody please help me with this? i
> even downloaded the latest harddrive and still does it?
Denise - Next time you have a problem, don't hijack someone else's
thread even if you think the issues are similar. Make your own post so
both posters can get help. If you are having difficulties printing with
IE, try this:
Start>Run regedit [enter]
Look for this key:
User Key: [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main]
Value Name: Use StyleSheets
Data Type: REG_SZ (String Value)
Find the value named "Use StyleSheets" and either delete it, or set it
to equal "Yes".
Malke
Elephant Boy Computers
www.elephantboycomputers.com
"Don't Panic!"
MS-MVP Windows - Shell/User
Reply to Malke
- 0 +
dont hijack someone else's thread? what do you mean by that? and by the way?
this is my first time on this forum and it wasnt done on purpose ok? and i
did what you suggested and i couldnt find anything that said "use style
sheets"... and please next time choose your words carefully about accussing
someone of "hijacking" thanks
> IE, try this:
> Look for this key:
> to equal "Yes".
> Malke
> "Don't Panic!"
Reply to Denise
- 0 +
> the way? this is my first time on this forum and it wasnt done on
> purpose ok? and i
> style sheets"... and please next time choose your words carefully
> about accussing someone of "hijacking" thanks
To hijack someone else's thread means to add your own question onto an
existing thread, which is what you did. I did choose my words
carefully; you need to learn about Usenet, using a newsreader, and
posting. Here are links to help you with that:
Since you are using the web interface (this is not a "forum" ), you may
not realize that this is really a newsgroup. You will get far more out
of this resource if you learn to use a newsreader. There are many good
newsreaders for Windows, but you can use Outlook Express since you
already have it. Here are some links to information about newsgroups:
http://www.elephantboycomputers.co [...] l#12-09-02 - a brief
explanation of newsgroups
http://michaelstevenstech.com/outl [...] reader.htm
http://rickrogers.org/setupoe.htm
http://support.microsoft.com/defau [...] efault.asp
- Set Up Newsreader
http://www.dts-l.org/goodpost.htm
http://www.catb.org/~esr/faqs/smart-questions.html
http://aumha.org/nntp.htm - list of MS newsgroups
microsoft.public.test.here - MS group to test if your newsreader is
working properly
http://www.mailmsg.com/SPAM_munging.htm - how to munge email address
http://www.blakjak.demon.co.uk/mul_crss.htm - multiposting vs.
crossposting
Malke
"Don't Panic!"
Reply to Malke
"Malke" <invalid@not-real.com> wrote in message
news:OEwE3JmgFHA.2852@TK2MSFTNGP15.phx.gbl...
> thread
lmao.
you must be new to newsgroups. Look for some articles on they work. Good
luck.
Reply to Anonymous
- 0 +
malke you're such know it all! you must get your manners from sears and
roebucks!! lol
> > purpose ok? and i
> - Set Up Newsreader
> working properly
> crossposting
> Malke
> "Don't Panic!"
Reply to Denise
- 0 +
> > > purpose ok? and i
> > - Set Up Newsreader
> > working properly
> > crossposting
> > Malke
> > "Don't Panic!"
Reply to Denise
- 0 +
anyway, ill just go to anothere newsgroup and to figure my printing problem
out...thanks anyway!
"Denise" wrote:
> > > > purpose ok? and i
> > > - Set Up Newsreader
> > > working properly
> > > crossposting
> > > Malke
> > > "Don't Panic!"
Reply to Denise
- 0 +
You need to learn some etiquette, and have you heard of the saying about
not biting the hand that feeds you? Malke was trying to help you . You
did hijack a thread ... which you shouldn't do. There may be few if any
willing to assist you now with your attitude.
Rock
MS MVP Windows - Shell/User
Reply to Rock
There are 1525 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 13 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
