C carol_06 Honorable Mar 5, 2012 1 0 10,510 Mar 5, 2012 #1 when i make a call or call numbers i hear a click noise
hang-the-9 Titan Mar 25, 2010 60,387 1,081 152,940 Mar 8, 2012 #2 You either enabled the sound for your button pushes, your speaker is going bad, or your phone is bugged. If you are a spy, the last is probably, otherwise, check with the cell provider on how to check what is happening. Upvote 0 Downvote
