Samsung Corby 2 memory problem
Last response: in Mobile Computing
unfortunately,there is no solution for this. It is because your system RAM get's full when you load the page. If you are browsing desktop version,switch to mobile. And if your browser has an option to reduce image quality,set it to minimum or low,close all apps running in background(if any)while browsing and uninstall or delete all unwanted apps and games from your phone. Use a lite theme. This may fix the problem
Ask the community
