Best answer from frozenlead.
Hi Guys
Got a Sony VAIO VGN-SZ1VP/C, it has a switch on it for speed or stamina, speed uses the NVIDEA video card, stamina uses the Intel video card to save power, if I boot in stamina it is fine, if I boot in speed the screen looks like the video memory is corrupt, it has lines and numeric characters on it, this happens from the BIOS screens to the blue screen of death when it stops so I don't think it is a driver problem, I think the Intel GPU is integrated, is the NVIDIA GPU on the motherboard or a daughter board? or anyone got an ideas?
Pete
Even if the GPU is a separate board - coming across a replacement is probably harder than finding a replacement motherboard...which isn't easy at all.
Sponsored Links
not sure, GeForce Go 7400, How can I tell if it is G84 or G86?
Pete
Reply to PoolQuePete
frozenlead wrote :
Is the GPU a G84 or G86?
Pete
then don't use stamina.
------------------------------ I joined fixya, good bye tom but you can come to my own forum www.laptopquestions.co.uk
frozenlead is a good member here for laptop questions
Reply to cheaptofix
G84 = 8400
G86 = 8600
I was thinking it was one of those chips that are known to be defective, but since it's not..
I'd say you got a bad 7400. Sony isn't known for quality parts.
Reply to frozenlead
frozenlead wrote :
G84 = 8400
G86 = 8600
Machine is 4 years old and has been working fine, I got it 1 week ago as a dud, not had back off yet, it looks interesting, don't want to spend a day with it in bits to find it needs a motherboard, I was looking for a ribbon cable out or a dud daughterboard and to make sure that I am going in the right direction, looks like I will be living with the Intel GPU, will keep checking this thread, thanks anyway.
Pete
Best answer
Reply to frozenlead
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > [Solved] Sony video problem
There are 610 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
