Archived from groups: microsoft.public.windowsxp.general (More info?)
Hi,
I have Windows XP Pro SP2, and I am constantly having problems whenever I
turn off my computer. It usually boots to the Desktop, after I login, but
then it immediately restarts. It comes to the Desktop again, and sometimes it
says that Windows has recoved from a serious error, and the error has been
fixed.
But this morning when I booted up, I got this message:
Quote :
lsass.exe - System Error
Indicates a revision number encountered or specified is not one known by the
service. It may be a more recent version that the service is aware of.
The only button available to click is , "OK", and I click it, and it just
restarts, and says the same thing again. This happens before the the login
screen, but after the Windows XP screen.
Please help me out! This has been happening to my computer and configuration
ever since I built the computer. So I am thinking that it has something to do
with my hardware.
Thanks for your time! (P.S - Computer Configuration Below.)
Sounds suspicious. What are the results of your anti-virus and spyware
scans? I would almost say you have the Sasser worm, but you don't mention
anything about the system shutting down on a regular basis.
"Ty" <Ty@discussions.microsoft.com> wrote in message
news:B05E8CA6-DF0F-4226-982D-AB77047861E2@microsoft.com...
> Hi,
it
> fixed.
Quote :
the
of.
configuration
do
> with my hardware.
> th3gh05t
I wish that I could run antivirus and spyware scans. But it doesn't allow me
to the Desktop. A couple days eariler, I installed McAfee 2005, and no virus
was found.
How do I fix the Sasser worm?
Thanks, Ty
> > Hi,
> it
> > fixed.
Quote :
> the
> of.
> configuration
> do
> > with my hardware.
> > th3gh05t
> allow me to the Desktop. A couple days eariler, I installed McAfee
> 2005, and no virus was found.
> Thanks, Ty
>> spyware
>> mention anything about the system shutting down on a regular basis.
>> > Hi,
>> > whenever I turn off my computer. It usually boots to the Desktop,
>> > after I login, but then it immediately restarts. It comes to the
>> it
>> > has been fixed.
Quote :
>> > known by
>> the
>> of.
>> > it just restarts, and says the same thing again. This happens
>> > before the the login screen, but after the Windows XP screen.
>> configuration
>> > something to
>> do
>> > with my hardware.
I think your feeling that hardware is at fault is probably accurate.
Since you built the computer yourself, you undoubtedly are comfortable
doing hardware testing. Here are some general hardware troubleshooting
steps. I would start with testing the RAM:
1) Open the computer and run it open, cleaning out all dust bunnies and
observing all fans (overheating will cause system freezing). Obviously
you can't do this with a laptop, but you can hear if the fan is running
and feel if the laptop is getting too hot.
2) Test the RAM - I like Memtest86+ from www.memtest.org. Obviously, you
have to get the program from a working machine. You will either
download the precompiled Windows binary to make a bootable floppy or
the .iso to make a bootable cd. If you want to use the latter, you'll
need to have third-party burning software on the machine where you
download the file - XP's built-in burning capability won't do the job.
In either case, boot with the media you made. The test will run
immediately. Let the test run for an extended period of time - unless
errors are seen immediately. If you get any errors, replace the RAM.
3) Test the hard drive with a diagnostic utility from the mftr. Usually
you will download the file and make a bootable floppy with it. Boot
with the media and do a thorough test. If the drive has physical
errors, replace it.
4) The power supply may be going bad or be inadequate for the devices
you have in the system. The adequacy issue doesn't really apply to a
laptop, although of course the power
supply can be faulty.
5) Test the motherboard with something like TuffTest from
www.tufftest.com. Sometimes this is useful, and sometimes it isn't.
Testing hardware failures often involves swapping out suspected parts
with known-good parts. If you can't do the testing yourself and/or are
uncomfortable opening your computer, take the machine to a professional
computer repair shop (not your local equivalent of BigStoreUSA).
