Tom's Hardware > Forum > Applications > Other Software > Power Point 2000 error message.
Forum Applications : Other Software - Power Point 2000 error message.
I cann't insert movies in in any slide show in PowerPoint 2000. Whenever I try to do so I get the error message, <b>"Power Point could not insert a movie from the selected file. Either the file is non-standard or Quick Time is not installed properly."</b>
I have installed Quicktime but of no avail. I don't think that files are non-standard as they can be inserted into PowerPoint 97 very nicely.
Any clues???
<b><font color=red><i>"All delays are dangerous in war."</b></font color=red></i>
Sponsored Links
I have finally discovered the solution of the problem from Microsoft Knowledge Base. I am posting it for the ease of those who might have been facing the same problem.
I foung following articles related to the probelm.
1.<A HREF="http://support.microsoft.com/default.aspx?scid=kb;EN-US;q212409&GSSNB=1" target="_new">PPT2000: Unable to Insert a Movie from the Selected File (Q212409)</A>
2.<A HREF="http://support.microsoft.com/default.aspx?scid=kb;EN-US;q235950&GSSNB=1" target="_new">PPT2000: Unable to Insert QuickTime Movies (Q235950)</A>
Apparently 2nd Article seems to be the exact solution because it contains exactly the same error message which I have mentioned in the question, but I found the solution in the first article.
I was trying to insert '.dat' files but dat extension was not registered in 'win.ini'.
Reply to xyz
There are 1179 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
