After about three years of reliable use, my Viewsonic VX910 LCD display color is tinted reddish orange and I cannot adjust it to its normal colors. I have been looking online to find a service manual or repair guide that would give me some chance to diagnose the problem but I've been unsuccessful in finding one. Does anyone have any suggestions or a source for a service manual or repair guide? Thanks.
I have a similar problem which began about a year after purchase. It is strangely intermittent...went on for about 3 weeks, quit for a few weeks and has resumed. Any dark display is tinted with red and light areas have swirls of blue green. Help?
I have the same problem, but my monitor is a VP930b. Were you able to solve your problem? Mine was working fine for 3 years and suddenly the problem appeared.
I discovered something extremely weird while in the monitor menu, If I went to "Color Adjust" and then to "User Color", the "R"ed bar would be out of the charts, it was marking 240, while the "G"reen and "B"lue were around 50. I moved the red back to 50 and it improved the color but did not fix the problem. I have tried to move the red or any other colors beyond 100 and the display does not let me.
I have a similar problem with the Blue on the User Color option for my ViewSonic VP930. I think the problem is in the memory settings for the monitor and some kind of short has shifted the values. I cannot change the value for Blue up or down using the OSD menu!
