I have verizon wireless enternet at home what woud be a good signal booster?
  • Wireless Access
  • Wireless
  • Verizon
Last response: in General Connectivity
September 10, 2012 2:08:10 PM
my enternet signal goes in and out way to often. I do live within the range of the single supposedly.
what signal booster do you recommmend?
More about : verizon wireless enternet home woud good signal booster
September 11, 2012 3:36:22 PM
If you are referring to a Verizon aircard or datacard, there are a couple of signal boosters on the market right now that can enhance the signal. The only one I've used is a zBoost booster by Wi-Ex. I use it for my phone signal because I have cable internet but it does claim to boost the signal of an aircard. Just check the specs of both the unit and your current internet setting to make sure they are compatible.
m
l
January 10, 2014 2:20:28 PM
I think that you should try 2.4GHz Long Distance Wi-Fi Signal Booster and Wireless Signal Amplifier.I have seen it on Ankaka.com and it looks pretty good.Working Range is 2400 - 2500 MHz so that is something that you should consider also.Anyway google it just to be sure and if you need best electronic gadgets try Ankaka.com atleast i did and it looks pretty cool because of many discounts that they give.It is the best electronics store for me at the moment.
Oh and i forgot to give you link for that Booster so here it is: http://www.ankaka.com/24ghz-long-distance-wifi-signal-b...
m
l
