Yes No
Ads
Tom's Hardware > Forum > Computer Brands > Compaq > R3360us - CPU Overheat Shutdown - Cleaning Help
Forum Computer Brands : Compaq R3360us - CPU Overheat Shutdown - Cleaning Help
Hey all,
Have read with interest the power cable discussions and others. Thanks, in advance, to all those who contribute time and knowledge here.
Our r3360us has begun shutting down, my guess is cpu overheat. Runs like a charm until someone does heavy cpu activity, then it shuts off.
I cleaned the air vents last week, they were quite clogged (multiple pets, dry air and dusty environs) and so I shudder to think how the internal heat sink and parts look.
What I'm asking for is directions on the best way to crack the case open to clean the internal heat sink and cpu area. Also, in the event I require replacement of my heat sink paste, what exactly am I asking for when I go shop?
I have decent layman's technical expertise. I've already removed and replaced a bad optical drive, etc. We're under warranty with Compaq (it's a business machine, so we bought the lonterm care plan) but I always prefer to fix in-house, we usually can't afford the 3-5 day turnaround and loss in productivity.
Thanks, in advance, agin, to any who can help. Have a wonderful Holiday Season!
Reply to StevenOfNine
I do not know if this models differs from the R3000, but the video tutorial topic might help. As thermal conductive paste I would go for Artic Silver 5. If your heatsink has multiple screws for tightening, tight/loosen them in a diagonal pattern, to get the heatsink down flat on the processor die and avoid cracking the core by putting to much pressure on single corners.
Reply to Que
There are 1640 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
What type of sound card does a dell dimentsion 8300 have
By Ubrales, 7 days ago:
Are the speakers turned OFF or disconnected? Check and make sure that the power adapter...
Best offers
