Archived from groups: microsoft.public.windowsxp.general (More info?)
I have an AOpen DVD Reader and a Samsung DVD Burner drive in my XP Pro SP2
system.
My problem is that whenever I put any CD or DVD in either drive the auto
play will not work, if I open up My Computer and click on the drive Icon it
will open up in the folder list but there is no Auto Play option.
I have run the CD Auto Play from K'K line 10 and also restore Auto Play
Icon, line 17 but none of these have worked
I have also run the repair tool from Kelly's Korner line 234 right hand side
but that is unable to repair the function. This is the log from that tool
AutoFix [V5.2.3790.67]
Time [2005-07-03 23:24:38]
Microsoft Windows Version [5.1 (Service Pack 2) <2600>]
Test [The Shell Hardware Detection service is running.] - Instance [N/A]:
Result [AutoStart Setting]: OK
Result [The Shell Hardware Detection service is running.]: OK
Test [Policies] - Instance [G:\, Drive Type: 5]:
Result [HKCU\...\Policies!NoDrives]: OK {Absent}
Result [HKCU\...\Policies!NoDriveAutorun]: OK {Absent}
Result [HKCU\...\Policies!NoDriveTypeAutorun]: OK {Present}
Result [HKLM\...\Policies!NoDrives]: OK {Absent}
Result [HKLM\...\Policies!NoDriveAutorun]: OK {Absent}
Result [HKLM\...\Policies!NoDriveTypeAutorun]: OK {Absent}
Result [Driver level policies]: OK {
HKLM\...\Services\cdrom!Autorun (Present) <Allows>
HKLM\...\Services\cdrom\Parameters!Autorun (Absent) <Allows>
HKLM\System\CCS\Enum\...!AlwaysEnable (Absent) <Not set>
HKLM\System\CCS\Enum\...!AlwaysDisable (Absent) <Not set> }
Test [Drive Notification] - Instance [G:\, Drive Type: 5]:
Result [Legacy Notification]: Problems
Result [AutoPlay V2 Notification]: Problems {
Service (Silent)
Shell (Deaf) }
>> Repair << [Legacy AutoPlay Event]
Step: No steps to take.
Result: This AutoPlay setting cannot be fixed. Either the device is
malfunctioning, or the wizard cannot determine the problem.
>> Repair << [Autoplay V2 Event]
>> Required action: The wizard found problems but cannot fix them -> None
Can anyone assist me please as I have run out of options.
Regards
Joe
Tasmania
system.
Service (Silent)
Shell (Deaf) }
Regards
Joe
Tasmania
