Tom's Hardware > Forum > General Networking > Network General Discussions > Help with Linksys Cable/DSL Router
Forum General Networking : Network General Discussions - Help with Linksys Cable/DSL Router
Well I don't have Cable or DSL and I just connected the Linksys router to a LAN backbone. Anyways now I can't figure out how to let my router link external and internal IPs. The computer on my private network has the IP 192.168.1.100 and I want it to link it to the LAN's (external) IP so that I can run my FTP server again. So if someone tries to connect to 128.xxx.xxx.xxx, then it automatically looks for 192.168.1.100 and not my other computers (192.168.1.101 and 192.168.100.102). I'm not sure how to do that. Also I'm not sure if my router will allow connections on port 21. Is it something to do with IP fowarding? Anyways I'm new to routers and any help would be appreciated.
Sponsored Links
well.....once you have your router setup on the network so that external hits will reach your router, you enter the routers setup menu by entering th eip address of the router in your browser....mine is 192.168.1.1
from the setup menu, you should hit the 'advanced' menu tab, then select forwarding. here, you can enter the FTP port (20-21) and tell the router to forward this fort to the IP address of your ftp machine. no problemo....
next, you will need to enter the 'filters' menu tab. at the bottom of the screen, select 'disable' for 'block WAN request'. This will allow WAN pings to reach your router, and then be forwarded to opther machines.
ignore everything i say
Reply to Anonymous
- 0 +
thanks antivirus! I did the first part, about the IP fowarding because I read it in a tutorial, but it never said anything about the "block WAN request"... just a simple click to disable it and everything works... but it doesn't seem that people on the Internet can connect to it... I only found that people on my network are able to connect to my FTP... I'm not sure if it's my router, or maybe the other person had connection problems...
Reply to No_Tone
is the router connected directly to an outside line? where does the cable that is going into the "wan" port on the router come from? Have you assigned the router a static IP address? if so, is it an 'external, routable' address?
Reply to Anonymous
- 0 +
I have my router connected to my university's LAN, and I'm not sure if each room is given a static IP or that I have to use DHCP.
Reply to No_Tone
I would guess DHCP...Are you using the router to connect to the internet? If you are and have not changed settings, DHCP.
"If you teach a child to read, then he or her will be able to pass a literacy test" - George W.
Reply to Red_Zealot
i think you have to have entered a static IP address in the router in order for the port forwarding aspect to work. but red zealot is also right, you probably need to run DHCP in order to accept an ID from your LAN server. If the DHCP server on your LAN issues external, routable addresses, you can sort of do both by doing the following: setup the router to obtain its IP address from the server (DHCP), which is probably how its setup now. then enter the routers setup interface again and click on the 'status' tab. here, your current router ip address and other relevant information is listed. this has been supplied to you through DHCP. copy all this down or print the page. now, go back to the 'setup' tab and select 'specify an address'. here, enter the information from the 'status' tab completely, including the DNS server address, gateway, etc. this way, you will never release your lease on that IP address from the DHCP server (because the router is always on it will always respond to the 'refresh' request), and can use that address to forward ports and receive internet pings, etc.
this has some drawbacks. if your IP address is everchanged on the LAN, you will have to adjust the information on the router as well. you will know if this happens because you will suddenly have no internet access.....
Reply to Anonymous
- 0 +
Thanks red zealot and antivirus! I just realized that when I pull the plug and plug it back in and redetect the proxy settings, the DCHP server gives me a new IP! So I guess I'll have to keep changing the IP in the router's settings in order to foward the ports. It's a pain in the ass but I guess it's the only way to run a server. Thanks you guys.
So basically what you're saying is to use the dynamic IP my DHCP server gives me and turn it into a static IP?<P ID="edit"><FONT SIZE=-1><EM>Edited by No_Tone on 10/28/01 05:28 PM.</EM></FONT></P>
Reply to No_Tone
yeah, thats my suggestion. i use the dynamic IP supplied by my ISP and turn it into a static one in the same way and it works fine. i hope the same is true for you. as long as you dont turn off your router, the DHCP server on your network should (theoretically) never release your lease on that IP address......goos luck, amigo.
ive been using the same 'dynamic' IP for over a year now.....
ignore everything i say<P ID="edit"><FONT SIZE=-1><EM>Edited by antivirus on 10/28/01 08:17 PM.</EM></FONT></P>
Reply to Anonymous
- 0 +
thanks antivirus! I owe you big time :)
Reply to No_Tone
There are 682 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
