CTRL+ALT+DEL problem
Forum Windows XP : Windows XP General Discussion - CTRL+ALT+DEL problem
Archived from groups: microsoft.public.windowsxp.general (More info?)
When I press CTRL+ALT+DEL the task manager appears for a second, then
minimizes itself to the icon tray. When I position the mouse over the icon
it disappears. I've run Norton Antivirus, Ad-aware, Spy Sweeper and
Microsoft Anti Spyware, but none of them identify a virus relating to this
problem. Has anyone seen this type of problem before ?
Sponsored Links
Yes, and it is related to one or more virus infections or other types of malware.
For additional help see www.dougknox.com, Win XP Utilities, Create Emergency Copies of Critical XP System Utilities. This small VB Program will create backup, usable copies of Task Manger, Regedit and MSConfig (named Copy_of_Taskmgr.exe, Copy_of_Regedit.com and Copy_of_MSConfig.exe) in a new folder C:\EmergencyUtil. Many virus programs will intercept these programs, based on their original file name. The modified file names, allow them to be run. Open Windows Explorer to C:\EmergencyUtil and double click the application you need. The next revision will allow you to browse for the folder you want to place the backups in.
In some cases, it may be necessary to rename even the backup copies, so that the filenames do not contain the exact wordings of MSCONFIG, TASKMGR and REGEDIT.
Additionally, see the Win XP Utilities section for Startup Programs Tracker. This small utility scans your system for startup programs and running processes. It also allows you to create a log file that can be copied and pasted into a newsgroup post. The contents of the program window are also copied to the Windows Clipboard, automatically. For replies to newsgroup posts, do NOT include the Running Services, unless its absolutely necessary.
Doug Knox, MS-MVP Windows Media Center\Windows Powered Smart Display\Security
Win 95/98/Me/XP Tweaks and Fixes
http://www.dougknox.com
Per user Group Policy Restrictions for XP Home and XP Pro
http://www.dougknox.com/xp/utils/x [...] onsole.htm
Please reply only to the newsgroup so all may benefit.
Unsolicited e-mail is not answered.
"john" <johnfkelly@cox.net> wrote in message news:%23OGrx1BgFHA.3256@TK2MSFTNGP12.phx.gbl...
Reply to Anonymous
Thank you. After creating and renaming the Copy_of taskmgr file I was able
to recover.
"Doug Knox MS-MVP" <dknox@mvps.org> wrote in message
news:e9W%23IfCgFHA.460@TK2MSFTNGP09.phx.gbl...
malware.
REGEDIT.
Display\Security
Reply to john
You're welcome :-)
"john" <johnfkelly@cox.net> wrote in message news:%23u$Y3WLhFHA.2904@tk2msftngp13.phx.gbl...
> to recover.
> malware.
> REGEDIT.
> Display\Security
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > CTRL+ALT+DEL problem
There are 901 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
