Acer 5630 help!!!!!
Forum Laptops & Notebooks : General Laptops & Notebooks - Acer 5630 help!!!!!
i just picked up a used acer 5630 from a reliable source, it was working fine, except it had some partitions that i wanted to change. I started formating using a windows xp pro disc. got pretty much through it until the computer shut off!
I booted it up and tried again with the same result, now it will only turn on for about a second, the battery light is on when plugged in.
What could be happening, is it a motherboard problem, some other forums lead me to that but with no answeres, the sepc on it are 1.6 core 2 duo, 1 gb ram.
Any ideas how to trouble shoot? I have looked through the acer manuals with no luck, PLEASE HELP!!!!
Sponsored Links
Take it apart piece by piece until you find a config that boots correctly.
Reply to frozenlead
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Acer 5630 help!!!!!
There are 1175 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
