Tom's Hardware > Forum > Motherboards & Memory > Memory > I think it's a memory problem... help!!
Forum Motherboards & Memory : Memory - I think it's a memory problem... help!!
From start to finish....
First time building without my dad, using an Abit VT7 mobo and P4 2.8Ghz with a 400w power supply. Originally I had a stick of 512MB DDR Crucial RAM in there and a nVida G-Force 4 video card. The first time I got everything hooked up on Friday, got started up beautifully and as expected. Made the mistake of hooking up the CD-R, floppy drive and sound card all at once before installing Windows, and after that it wouldn't boot up, even when I went back to the original setups and just processor, mobo and memory. No sync with the monitor (when I had the video card in) and I got nothing but a long beep, then a pause, then the long beep again - which I discovered by reading the FAQs here a few minutes ago is most likely a memory problem.
Abit tech support today said it's the memory beep code, so I was told that if moving it to a different slot did nothing my Crucial memory was probably incompatible. Ok, that's fairly simple to fix, I say to myself. My boyfriend suggested I try powering up without any RAM in there (so it's just processor and mobo) and I got the same beep code - and neither of us was sure if that was supposed to happen or not. Tried the Crucial again, same problem. Ran out to Circuit City to get a 256MB DDR Kingston stick, thinking it's a compatibility issue. Doesn't work. Humor myself by trying the other slots, no luck. Looked online right now and see yes, my Crucial WAS compatible with my mobo.
So now I'm horribly confused on what's wrong. I doubt I killed <fill-in-the-blank> by popping in those devices way back when (after tech support lines closed :/) but if it's the memory like the beep suggests, what do I do to fix it? It's in the all the way with the tabs snapped and down, so I know it's not not fully connected. And if it's not a memory problem, then what IS wrong? I'm slightly frantic because I leave for school on Thursday, and it's going to be Tuesday when I can get ahold of more tech support people - going to call Intel, Abit and Crucial and talk to whoever is open earliest.
Sponsored Links
Read your m/b manual to see what the beeping codes are...
Reply to RichPLS
Clear the CMOS and try the module again with everything plugged in. Could be your power supply can not handle the load. Is the power supply a top name brand or a generic? Make sure the module is fully seated or you might fry the motherboard.
Crucial Performance Lab
www.crucial.com
The Memory Experts(SM) at Crucial Technology is now on board to give you straight answers to your memory-related questions.
cpl@micron.com
Reply to CrucialLabs
Cuz crucial memory never fails right :wink: .
If you tryed different ram it could be a motherboard problem. Maybe it died after your first boot...
Try clearin the Cmos like Crucial mentioned
Asus P4P800DX, P4C 2.6ghz@3.25ghz, 2X512 OCZ PC4000 3-4-4-8, Leadtek FX5900 w/ FX5950U bios@500/1000, 2X30gig Raid0
Reply to Anonymous
- 0 +
RichPLS - The manual doesn't list ANY beep codes, nor does the Abit webpage even LIST the VT7 in its help section :(
CrucialLabs - I've cleared the CMOS every time I tried something new. I thought it wasn't seated right in the case as well, so this afternoon I took it out and powered it up when it was on some cardboard. Same beep :/ The power supply is Enermax, which I've had recommended to me by other builders so I don't think that's it (unless I just have a bad unit?)
labbbby - Yeah... right now I'm pretty sure it's either the mobo or the CPU, but the board's light goes on and I'm still getting that beep so I doubt it's fried completely... I'm currently trying to see if I can test either my boyfriend's or my dad's processor (they both use Athlon, would that work?) on my board and see if that works to rule something out.
Reply to Marivel
Whatever you do DONT try to fit an Ahtlon in there!
My guess is that its your motherboard. Everything might work fine xept for the memory controller/meory slots whatever...If the tech told you it was a the memory error beep codes, id trust them.
Since you tried different memory and crucial is really reliable anyhow, you can exclude memory.
In the end youd have to try it in another case with a jsut to make sure its not the PSU (cause a 400whatt enermax should be plenty but theres a slim chance that its flakey)
Try to isolate the problem as much as possible but Im pretty sure it would be your motherboard.
Btw if you list your dads/bf system, we could tell you if you can put your crucial memory in their system to make sure its not the problem.
Dont give up heh
Reply to Anonymous
- 0 +
The actual memory slots... yeah that might very well be it since it'd explain everything, but I'm going to try to narrow it down as much as I can. What's the minimum power supply I'd need to run a Abit VT7 with a P4 2.8Ghz? If it's more than 200w *my dad's case* looks like I'll be carting over to my boyfriend's place and testing it there.
So if it works in another case... it's the power supply in mine that's the problem. And if it doesn't... how do I narrow it down further, since everyone I know has an Athlon system? I leave for school on Thursday so I'd really like to have my computer all fixed up before that...
<P ID="edit"><FONT SIZE=-1><EM>Edited by Marivel on 08/24/04 06:42 PM.</EM></FONT></P>
Reply to Marivel
You want at least 300 watts for that rig. It's getting hard to find an ATX with less. Don' try and run that pig on 200 watts.
Abit IS7 - 2.8C @ 3.4ghz - Mushkin PC4000 (2 X 512) - Sapphire 9800Pro - TT 420 watt Pure Power
Samsung 120gb ATA-100 - Maxtor 40gb ATA - 100
Sony DRU-510A - Yellowtail Merlot
Reply to Cybercraig
There are 900 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
