Archived from groups: microsoft.public.broadbandnet.hardware (
More info?)
Thank
Yes I all test from inside network, but why in one server
(1) run OK and other (2) NOT?. Both server with the same
config., but diferent IP and diferent ISP
Thank
PTTK
>-----Original Message-----
>Are you testing access from inside your own network,
using external names?
>If so, it will fail due to the MN700's lack of loopback
support.
>Loopback support should be added in the next firmware
update.
>Jason Tsang - Microsoft MVP
>Find out about the MS MVP Program -
>http://mvp.support.microsoft.com/default.aspx
>"pttk" <anonymous@discussions.microsoft.com> wrote in
message
>news:2808401c46475$0f80b160$a601280a@phx.gbl...
>> Thank
>> I change FTP service in Server 1 to port 21, but not
work:
>> "Timer cancelled blocking call"
>> "Accept error: blocking call cancelled"
>> "Retrieve of folder listing failed"
>> Error in WS_FTP in passive or not passive mode
>> Both server have equal config.!
>> Any idea?
>> PTTK
>> >Active mode issues are generally the fault of the
client
>> (not server side).
>> >Active mode behind a firewall/shared connection is
>> generally difficult to
>> >do, because listening ports need to be dynamically
opened
>> (port is
>> >determined by the ftp client during directory listings
or
>> transfers).
>> >Many routers provide an ALG on port 21 to listen on FTP
>> commands to sniff
>> >out the port that needs to be open for active mode to
>> work. However, that
>> >only works on port 21 in most causes.... so it doesn't
>> work on non-standard
>> >ftp ports.
>> >Your best bet is to setup your FTP server for passive
>> mode FTP (you'll need
>> >to forward an additional range of ports to the computer
>> running the FTP
>> >server, specify within IIS to use those forwarded
ports,
>> and tell IIS to use
>> >your WAN ip as the passive mode ip).
>> message
>> >news:27cd301c46443$3c06c6c0$a601280a@phx.gbl...
>> >> Hi,
>> >> I have two out FTP service, one in 21 port and work
ok,
>> >> another in port 2121 (in another server), WS_FTP
>> send "500
>> >> invalid PORT comand". Both service in W2YK machine's
and
>> >> in IIS service.
>> >> In my MN-700 I "open" only port 2121 to my PC
>> >> Any idea?
>> >> PTTK
