Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Problem with Shortcut - updater.lnk
Forum Windows XP : Windows XP General Discussion - Problem with Shortcut - updater.lnk
Archived from groups: microsoft.public.windowsxp.general (More info?)
I am having trouble finding any information on this issue. There is more than
one user getting this error message. The message reads:
"Problem with Shortcut
The drive or network connection that the shortcut 'updater.lnk' refers to is
unavailable. Make sure that the disk is properly inserted or the network
resource is available, and then try again."
It occurs at startup after the user logs on. I even looked in the Microsoft
KB, but no luck. I'm not sure if I should trust any other sources online.
Thanks for reading.
Kristi
Sponsored Links
There is an invalid entry in your startup settings. See "How to
Troubleshoot By Using the Msconfig Utility in Windows XP"
(http://support.microsoft.com/?kbid=310560) and "How to Modify the
List of Programs that Run When You Start Windows XP"
(http://support.microsoft.com/?kbid=314488).
(tm)
ICQ: 192649233
Reply to Anonymous
There are 1061 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
