Point-and-click text interface?
Archived from groups: rec.games.int-fiction (More info?)
I was just having a discussion about interactive fiction with someone
who played the Infocom games back in the day and found them frustrating.
He has an idea in his head of how he would like an interactive fiction
game interface to be played, and while the idea doesn't appeal to me at
all, I didn't see why it couldn't be done, so it made me wonder if it,
in fact, *has* been done. (I wouldn't be that shocked.)
His idea was essentially that you could have a region of the screen that
listed all the verbs that the interpreter knew, then another region of
the screen that listed all the currently available objects (perhaps
separated into objects in your inventory and objects in your region that
weren't in your inventory). Perhaps another element which showed all
the available navigation directions and then something for
save/load/etc. would also be required to make it complete. The idea
would be that you could just click on the words in the lists and have
that drive the game.
I believe that his chief aim in all of this was to solve possible
frustation with not knowing what word to use in a given situation.
Anyway, I thought I'd inquire about whether something like this had ever
been done, or if not, if it seemed plausible (assuming that you wanted
this thing to be able to drive story files from some existing system
like inform or tads or something, rather than being a whole new deal).
16 answers Last reply
More about point click text interface
  1. Archived from groups: rec.games.int-fiction (More info?)
    > that listed all the verbs that the interpreter knew, then another
    > region of the screen that listed all the currently available objects
    > (perhaps separated into objects in your inventory and objects in your
    > region that weren't in your inventory). Perhaps another element
    > which showed all the available navigation directions and then
    > something for save/load/etc. would also be required to make it
    > complete. The idea would be that you could just click on the words
    > in the lists and have that drive the game.
    Sounds like Wandmaster. Or possibly Quest games, of which I haven't played
    many, so I could be wrong. For Wandmaster, see http://wurb.com/if/game/1946.
    I think it definitely made it easier to see which objects could be used, but
    there can still be frustrations with bugs, puzzle design, and the
    point-and-click interface. Oh, you know what would be even better than
    Wandmaster? See Sweet Dreams from last year's Comp:
    http://wurb.com/if/game/2188
    That was actually a neat little game.
    --Jess
  2. Archived from groups: rec.games.int-fiction (More info?)
    "Irfon-Kim Ahmad" <irfon@ambienautica.com> skrev i melding
    news:eHSQc.4$9x61.3@news04.bloor.is.net.cable.rogers.com...
    Eric the unready http://www.the-underdogs.org/game.php?id=375
    and the spellcasting series
    http://www.the-underdogs.org/game.php?gameid=1027
    does this.
  3. Archived from groups: rec.games.int-fiction (More info?)
    Irfon-Kim Ahmad <irfon@ambienautica.com> wrote in message news:<eHSQc.4$9x61.3@news04.bloor.is.net.cable.rogers.com>...
    While it's not "interactive fiction" under the strictest definition,
    you might be interested to know that one text-based multiplayer
    roleplaying game has adopted this ability (GemStone IV --
    www.play.net/gs4). It's part of their StormFront front end, and,
    while I don't personally use point-and-click (I type faster than I
    point-and-click through drag-down menus) I know that a large part of
    the customer base finds it quite useful. This is particularly true of
    those just starting out in the game -- something about being able to
    point-and-click instead of type is very encouraging to new players.
    I went looking for more information about it on the website, but I
    couldn't seem to find anything geared toward explaining StormFront in
    detail, unfortunately. (The FAQ is at
    http://www.play.net/gs4/play/sf/faq.asp , but it's intended for a
    player already familiar with their Wizard FE, and, as a result, it
    doesn't make a lot of sense at a glance.) GemStone does have a 30-day
    trial period, though, so, if you're particularly curious, you could
    peek in and see how it's been implemented without any obligation.
    Carolyn
  4. Archived from groups: rec.games.int-fiction (More info?)
    > screen that listed all the verbs that the interpreter knew, ...
    Labyrinth for the C64 did this, and I think Maniac Mansion (C64) did as
    well. These were animated graphical adventures, but the interface was text
    based. There were other elements to the interface as well (in Labyrinth:
    walk with joystick, press the button to call the command menu).
    I found it worked pretty nicely in Labyrinth. The game seemed to handle
    the scope of each noun properly. No time was really saved, because you had
    to scroll through the lists of verbs and nouns to construct your command,
    but it did make typos and spelling errors impossible.
    For a graphical game where you used the joystick to walk around, I
    enjoyed the interface because it kept my hand on the joystick. For a
    pure-text game, I'm not sure I'd like it -- I'm a fairly fast & accurate
    typist, so it would more than likely slow me down. A 20wpm, hunt-and-peck
    typist might really appreciate it. I certainly have nothing against it.
    S.
  5. Archived from groups: rec.games.int-fiction (More info?)
    The AGT Big game about Sherlock Holmes acted this way. (Personally, I think
    that it was more as an excersise proving what the language could do than an
    actual game, as it isn't exactly all that great.) Also< I believe that the
    Multi-Dimentional Thief had a point/click interface in one of the versions.
    Finally, if I do recall, a good part of Adam Cadre's _Lock and Key_ could be
    solved by doing some mouse clicking, if one so desired. (And if not, to be
    honest, maybe it should.)
    _____
    Why settle for the lesser evil? Cthulhu for president!
    "Irfon-Kim Ahmad" <irfon@ambienautica.com> wrote in message
  6. Archived from groups: rec.games.int-fiction (More info?)
    Maybe this gives you some idea?
    http://groups.google.com/groups?threadm=90a69809.0405250120.163b998c%40posting.google.com
    Cheers, Roger
    You'll find all my IF pages at http://www.firthworks.com/roger
    WARNING: aggressive spam deletion -- use a meaningful Subject!
  7. Archived from groups: rec.games.int-fiction (More info?)
    Irfon-Kim Ahmad <irfon@ambienautica.com>, you wrote on Fri, 06 Aug
    2004 21:25:30 GMT:
    Didn't one of the later Infocom games have clickable directions?
    There has been some discussion on how to avoid the dreaded disease of
    "guess the verb". I cannot remember the particulars, but undoubtedly
    Dejanews, er, Google Groups can help you there:
    <http://groups.google.com/groups?q=%22guess+the+verb%22+group%3Arec.arts.int-fiction+>.
    Also, it seems that a system in which you have Monkey Island type
    discussions with NPCs has enjoyed some success recently.
    branko collin
    collin@xs4all.nl
  8. Archived from groups: rec.games.int-fiction (More info?)
    Yes.
    It's been done (pretty well, IMHO).
    Unfortunately, the tool appear to be un-supported
    at the moment.
    http://www.btinternet.com/~sudslore/
    Bye,
    Rob
    Posted via Mailgate.ORG Server - http://www.Mailgate.ORG
  9. Archived from groups: rec.games.int-fiction (More info?)
    On Fri, 6 Aug 2004 17:58:49 -0400, Jess Knoch <jessicaknoch@mindspring.com> wrote:
    (snip)
    > --Jess
    It was an interesting game, but the engine needed a bit of work due to the
    author's rush to release in time for the comp; did Papillon ever do a
    post-comp release?
    Mark Jeffrey Tilford
    tilford@ugcs.caltech.edu
  10. Archived from groups: rec.games.int-fiction (More info?)
    > <jessicaknoch@mindspring.com> wrote: (snip)
    > to the author's rush to release in time for the comp; did Papillon
    > ever do a post-comp release?
    I got a second version of it, with some fixes for font sizes. Other than
    that, I don't recall any. It'd be nice though; there were definitely a few
    issues with moving around and such.
    --Jess
  11. Archived from groups: rec.games.int-fiction (More info?)
    Hi. Just lurking ...
    I've made two such games. Both short and simple. One last year; and I
    finished the other last week. They are not quite like what you mention. But
    you have only a mouse interface. They are more like the "Create Your Own
    Adventure" style. They are in HTML. I found it interesting the things you
    could do with just HTML links. I'm just experimenting and having fun with
    this. Take a look and let me know what you think. They are at:
    http://myweb.cableone.net/lwmurphy/lis.htm
    and
    http://myweb.cableone.net/lwmurphy/los.htm
    Best regards,
    Lyle
  12. Archived from groups: rec.games.int-fiction (More info?)
    Heya.
    Lyle wrote in message <10ho24pjcjq3tfe@corp.supernews.com>...
    >and
    >Best regards,
    >Lyle
    The first one gives a 404, the other one is like the old DOS batch adventure
    Marvin. It works like yours: just choose and hope it is the right way...;).
    Like that.
    Greetz, Katzy.
  13. Archived from groups: rec.games.int-fiction (More info?)
    "Katzy" <katzy@noname.at.all> wrote in message
    news:10hp89ngt0i4847@corp.supernews.com...
    > Heya.
    But
    > >and
    > >Best regards,
    > >Lyle
    adventure
    way...;).
    > Like that.
    > Greetz, Katzy.
    Sorry about the 404. I deleted the games as it was a parody on a copyrighted
    material. If anyone knows this Graeme Cree fellow tell him thanks or send
    me his email. I doubt there really is a problem anyway. But it is now
    changed and still just as funny and quirky. It is back up there as
    The other as http://myweb.cableone.net/lwmurphy/los.htm. (I'm biting my lip
    on this game. I would loved to have talked to Mr. Cree first.)
    Lyle
  14. Archived from groups: rec.games.int-fiction (More info?)
    "Lyle" <lwmurphy@cableone.net> wrote in message
    news:10hqmlp58l697ec@corp.supernews.com...
    He's still around. Reaching him may take a while though:
    http://groups.google.com/groups?hl=en&lr=&ie=UTF-8&c2coff=1&selm=20030523234618.20312.00000310%40mb-m01.aol.com
  15. Archived from groups: rec.games.int-fiction (More info?)
    Legend's _Gateway_ games did this, and they're considered classics (although I
    never used the list myself).
    Joe
  16. Archived from groups: rec.games.int-fiction (More info?)
    Sounds almost exactly like "Tass Times in Tone Town" by Interplay. The
    interface used graphical icons for the inventory items and verbs, but it was
    true interactive fiction and you could type all of your commands if you
    prefered.
Games Video Games
