Yes No
Ads
Tom's Hardware > Forum > Windows XP > General Discussion > resolution and sound
Forum Windows XP : General Discussion resolution and sound
Archived from groups: microsoft.public.windowsxp.general (More info?)
So I was being a wise guy and decided to uninstall things in my laptop. its
a acer travelmate 2500 and worked so well. i bought it from a friend so no
warranty or company support.
two things disappeared that seem to be of consequence.
1. I lost the button that helps me change resolution. the only resolution
changes that i have available are in desktop properties> settings. 1024x768
and 800x600. when the screen display moves in any software, the scrolling is
slow and doesnt flow smoothly anymore. its like its moving 5 lines at a
time... and that gives it a wavy feeling going up and down. i have a
headache with that!
2. Also, I cant see the sound volume button anymore to change sounds. come
to think of it, i havent heard sounds on my laptop since yesterday. anyone
know what i can do? id appreciate any help!
esoteric_astute
Reply to Anonymous
> laptop. its a acer travelmate 2500 and worked so well. i bought it
> from a friend so no warranty or company support.
> resolution changes that i have available are in desktop properties>
> settings. 1024x768 and 800x600. when the screen display moves in
> any software, the scrolling is slow and doesnt flow smoothly anymore.
> its like its moving 5 lines at a time... and that gives it a wavy
> feeling going up and down. i have a headache with that!
> sounds. come to think of it, i havent heard sounds on my laptop
> since yesterday. anyone know what i can do? id appreciate any help!
Well download and reinstall the drivers then! I can't see it takes a genius
to figure that out!
Reply to Anonymous
well see i am NOT a computer genius at all. I'm a finance guy. Not sure
where to get the drivers and not sure which ones I need :(
esoteric_astute
> to figure that out!
Reply to Anonymous
A good place to start would be http://global.acer.com/
Reply to Anonymous
"esoteric_astute" <esotericastute@discussions.microsoft.com> wrote in
message news:39DC258B-DC19-4B3F-B977-AF9922A38715@microsoft.com...
Don't worry about it; nor is she.
ss.
>> genius
>> to figure that out!
Reply to Anonymous
i checked that out but i cant seem to find the downloads for this stuff!
esoteric_astute
Reply to Anonymous
- 0 +
> stuff!
Acer 2500 notebook
http://www.acerpanam.com/synapse/f [...] om&pupv=pu
I didn't see any downloads for sound(must be intergrated)but their is one
for your Video.
Start here for your sound troubleshooting
http://www.kellys-korner-xp.com/top10faqs.htm
Good Luck.
Mike Pawlak
Reply to map
HI Mike,
Thanks for your help with this one. got the video thing sorted out. got
the resolutions icon back and the display is so much smoother now. You know
your stuff!
I still can't seem to get the volume control button to come back :( not
sure how to get that done.
esoteric_astute
> > stuff!
> Acer 2500 notebook
> for your Video.
> Good Luck.
> Mike Pawlak
Reply to Anonymous
- 0 +
In control panel click on sounds and audio devices,under the volume tab
their should be a box to place the volume control on the taskbar,check this
box and click apply.
Mike Pawlak
> HI Mike,
> got the resolutions icon back and the display is so much smoother
> now. You know your stuff!
> not sure how to get that done.
>>> stuff!
>> Acer 2500 notebook
>> is one for your Video.
>> Good Luck.
>> Mike Pawlak
Reply to map
You can find the sound card driver at
http://support.acer-euro.com/drive [...] _2000.html
It's the third one down (Realtek Semiconductor AC'97 Audio Driver
version 5.10.0.5550)
Reply to Anonymous
- 0 +
In addition:
Restore Volume and Net Icon to Notification Area (Line 320)
http://www.kellys-korner-xp.com/xp_tweaks.htm
Troubleshooting the Volume Control Icon
http://www.kellys-korner-xp.com/xp_v.htm#volume
Volume Icon Is Displayed Incorrectly in the Notification Area After the
Computer Resumes from Standby
http://support.microsoft.com/defau [...] duct=winxp
Troubleshooting the Notification Area
http://www.kellys-korner-xp.com/xp_n.htm#na
All the Best,
Kelly (MS-MVP)
Troubleshooting Windows XP
message news:F203866A-9917-4728-8080-372B26EBFD7F@microsoft.com...
> HI Mike,
> know
> your stuff!
> esoteric_astute
>> > stuff!
>> Acer 2500 notebook
>> for your Video.
>> Good Luck.
>> Mike Pawlak
Reply to kelly
heres what it says when i do that..
windows cannot display the volume control on the taskbar because the volume
control program has not been installed. to install it, use add remove
programs in control panel.
when i go to add remove... i cant seem to get anything done to download and
install volume control.
esoteric_astute
> Mike Pawlak
> > HI Mike,
> >>> stuff!
> >> Acer 2500 notebook
> >> Good Luck.
> >> Mike Pawlak
Reply to Anonymous
- 0 +
Common issue as I stated before. The procedure is listed below:
Windows cannot display the volume control on the taskbar because the Volume
Control program has not been installed. To install it use Add/Remove
Programs in Control Panel.
To resolve this issue, extract a new copy of Sndvol32.exe from the Windows
XP CD to the system_root \System32 folder on your computer's hard disk. To
do this, follow these steps:
Start/Run/CMD. In the command prompt window type:
X: (where X is your CD Drive letter)
CD \I386
Then use the expand command:
expand -r sndvol32.ex_ c:\windows\system32
Note: This assumes XP is installed on C: and that its installed in the
Windows folder. If not, you'll need to adjust the command accordingly.
Additionally, this must be an installable version of XP, not a "recovery
CD".
All the Best,
Kelly (MS-MVP)
message news:225F8308-F5D7-4F57-86C9-CD689A709568@microsoft.com...
> volume
> and
> esoteric_astute
>> this
>> Mike Pawlak
>> > HI Mike,
>> >>> stuff!
>> >> Acer 2500 notebook
>> >> Good Luck.
>> >> Mike Pawlak
Reply to kelly
kelly,
thanks for your email. i dont have the xp cd. it all came installed in
this used laptop i bought a few months ago. is it possible to download
Sndvol32.exe from somewhere? is it possible for you to email it to me?
esoteric_astute@hotmail.com
appreciate all the help.
esoteric_astute
> CD \I386
> CD".
> All the Best,
> Kelly (MS-MVP)
> > volume
> > and
> > esoteric_astute
> >> this
> >> Mike Pawlak
> >> > HI Mike,
> >> >>> stuff!
> >> >> Acer 2500 notebook
> >> >> Good Luck.
> >> >> Mike Pawlak
Reply to Anonymous
It doesn't take a genius to know how useless your posts are does it?
"Miss Perspicacia Tick" <test@test.com> wrote in message
news:Xb_ye.446$y86.173@fe03.ams...
> genius to figure that out!
Reply to Anonymous
- 0 +
You are most welcome; however, I haven't emailed you. This is a newsgroup.
:o)
As for the download, try here:
http://members.driverguide.com/dri [...] erid=83732
They claim it works for XP as well. Good luck!
All the Best,
Kelly (MS-MVP)
message news:22EA361A-0EE2-45A3-9C2D-A101C28D580E@microsoft.com...
> kelly,
> esoteric_astute
>> Volume
>> Windows
>> To
>> CD \I386
>> CD".
>> All the Best,
>> Kelly (MS-MVP)
>> > volume
>> > and
>> > esoteric_astute
>> >> tab
>> >> this
>> >> Mike Pawlak
>> >> > HI Mike,
>> >> >>> stuff!
>> >> >> Acer 2500 notebook
>> >> >> Good Luck.
>> >> >> Mike Pawlak
Reply to kelly
There are 1663 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Password
By ksiemb, 13 hours ago:
Cannot help with password retrieval. - Forum Rules.
Best offers
Top experts
