Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > baffling monitor power off?!
Forum Computer Peripherals : Flat Panels/ LCDs - baffling monitor power off?!
I have a 24" Acer flat panel.
the problem is that every now and then the monitor would just turn off. The yellow power light would be on but the screen will be black. I turn off the monitor and switch it on again and the monitor will stay on for a few seconds and would go dead again.
The only solution seems to be to keep the monitor off for something like 5 to 10 minutes. After that it will work like a charm.
This happens every now and then but not very frequently.
Anyone know whats happening??
Sponsored Links
I have the same monitor and what PSU wattage do you have becasue many of the problems with these monitors is nnot having enought power from the psu.
Reply to Haltech123
I have a 550Watt psu
Reply to betrayer_
might be close depends on how many optical drives do you have good luck
Reply to Haltech123
my monitor takes power seperately. not from the psu.
Reply to betrayer_
There are 1099 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
