After you reinstall windows to your harddrive, assuming it is not a SATA, and assuming you are formatting them, it should automatically be the new C: drive. I would make sure the partion you are using is the first partition on the drive.
On my SATA drive, I have to unplug all the other drives before I install Windows, otherwise my computer sets my SATA to D:. After Windows is installed I replug in the drives so Windows can detect them.
My Desktop: <A HREF="http://Mr5oh.tripod.com/pc.html" target="_new">http://Mr5oh.tripod.com/pc.html</A>
