Tom's Hardware > Forum > Computer Peripherals > Flat Panels/ LCDs > Weird problem with my LCD
Forum Computer Peripherals : Flat Panels/ LCDs - Weird problem with my LCD
I got my new LCD for my birthday, I really like it. Other than if I leave it on for awhile, the display will really mess up. The bottom half of the monitor will show the top of the actual resolution. And the far left will show the far right.
It stays this way even if I unplug the monitor from my videocard. The problem seems to be fixed if I unplug the power and let all the components in the LCD empty. I plug it back in and it's normal. I never had this problem with my CRT. Even when my computer is turned off and not connected to the LCD the monitor will still be at this setting until unplugged. I guess its tollerable, but really annoying. Any way to fix it? Thanks a ton!
BTW, I'm using VGA, not DVI.
Sponsored Links
There are 459 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
