i recently bought a maxtor 160gbdrive to replace my 80 gig one. my sister wasn't using her computer so i just stuck it in their for safe keeping. Now i have a lot of files to back up and wanted the 80 gig hd for a backup, i would stick all the big files on it and when i format i just put it in and transfer them. However when i put it in, it says please insert system disk. So i tried putting in a boot up floppy for win 98, that didnt work, so then i tried putting a cd in for win xp and that didnt work. does anyone have any ideas what the problem is with this one?
the second one is my sisters 40 gig one, when the 80 didnt work i thought well i will jus have this one instead. So i put it in and when it is detecting hard dirves at the start it doesnt detect it ,even if i go into bios. Instead it stays on the detecting hard drive screen with the 40 gig HD making the popping noises it makes. it goes pop pop pop quite fast and then just stops and then it repeats it. does any one know what the problem with this one is?
thanks for any replies
athlon 2500
512mb corsair xms 3200
radeon 9800np
80 gig hd
athlon 2500
radeon 9800np
80 gig hd
