Tom's Hardware > Forum > CPU & Components > Sound Cards > audigy 2 zs rear speakers problem
Forum CPU & Components : Sound Cards - audigy 2 zs rear speakers problem
i have the logitech 640z speakers plugged into my audigy 2 zs sound card, the front, center and subwoofer work perfectly, but my rear speakers has no sound coming out of it only a slight buzz, it worked before though, so anyone know what's the problem?
Sponsored Links
restore everything to defaul through the
creative restore defaults icon
then make sure your speakers are set to 5.1
If that doesnt work make sure your running the newest drivers
Also make sure that all your connections are plugged in, on the speakers and on the sound card
System Spec's:
3.2e @3.8ghz
klipsch ultra's
"After careful deliberation i have concluded that I am an idot"
<A HREF="http://www.freewebs.com/lb19984/" target="_new">My Computer</A>
Reply to lb19984
That's actually been a common problem with previous versions of the card, this is the first time I've heard of it on the ZS. It's a driver/application configuration issue. So now that you know it's most likely software, you can try resetting the application or whatever you Creative Technicians do.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
There are 813 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
